Remove reflections
I'm trying to get a pair of eyes with no reflections. Usually I render with reflections but this time I just need matte and I can't seem to remove them.
I pretty much zeroed every setting for Iris, Pupil and Sclera except for Diffusion and still I get reflection. Turning off the environment did not help much either.
What am I missing?
For G3F / G8F, did you check the 'EyeMoisture' surface?
Yes I did and zeroed that too, except for Diffuse, the Opacity is at 0%. It's definitely the headlight reflecting. If I put other lights then I can see those reflections instead.
Ok, one option left you did not mention, the cornea; I tried this on G8F. Setting the opacity to zero eliminated the refelction in my testrender
I worked on the cornea but still get those two reflections. This is just default G3 female figure using Imogen eyes.
Running out of options... I don't have (any of) the 'Imogen model(s), so can't try that out.....
