Issues with Dynamic Lingerie Collection for Genesis 2 and V6
somathatsomathat Posts: 32
I recently bought Dynamic Lingerie Collection for Genesis 2 and V6 which works great on G2(Genesis 2) and V6 when first loaded,my problem is when I add any morphs to the figure(Height,or any other morphs)The clothes do not compensate for the morphs and load on a pre morphed position.When I try to drape the cloth it falls to the floor-What am I doing or not doing??I am using Daz 4.6(latest version),Win 8 64 bit with 16 gigs of ram I 7 processor-Any help would be appreciated:))
  • somathatsomathat Posts: 32
  • MattymanxMattymanx Posts: 6,997
    The OptiTex dynamic cloth is not scaleable. None of it is or has been. Its the way that system works.
    A work around would be to scale the character up or down after applying the desired morphs and scale everything else in the scene to the same percentage. I have done this to fit V4 dynamic cloth to Aiko3 by scaling her up and everything else with her to make the clothes fit.
    Well,that sucks:((-Thanks for the quick reply,Hard to believe that Dynamic clothes wont work on morphed figures-Defeats the whole purpose:((
    You would think with all the tech involved with this it would be a simple click,load and drape-Complete waste of 17 dollars:(((
  • Richard HaseltineRichard Haseltine Posts: 108,568
    You can ask for a refund. The OptiTex clothing behaves like real clothing, in that it is made for a size and shape - unfortunately there are unlikely to be multiple sizes on the rail.
    Merged duplicate threads
  • jerhamjerham Posts: 155
    They way i use dynamic clothing in combination with morphs:
    - Load V6 in frame 1
    - Go to frame 30 (or how much frames you like), and pose and shape her.
    - From the dynamic clothes control, drape frame 1 (should give no problems, since it a standard figure)
    - From the dynamic clothes control, use the animated option to drape the next 30 frames.
    Now the cloths follow the morphes nicely.
    How ever 2 things;
    - be careful with the length, size morphes. If the figure is smaller adjust the size in frame 1 (both the figure and the clothes)
    - Some parts of the dynamic Lingerie set (shoulder straps for instances) have the annoying thing that they fall through V6 with extreme morphs/poses. So that is a bit trial en error.
    I cant even drape one still frame,lol,but thanks for your help:)I thought it would be a little more user friendly-the ad on site should include a disclamer:((
    edited July 2013
    From this i understand it immediately falls thru her?
    Did you check the collision items in the dynamic control, if the collision items are set right (V6 especially) is selected?
    It is under the button collide with...
    EDIT.
    Also check if you have the latest version of the dynamic clothing control installed. This one does not work with DIM but you have to download it manually form youre account. Had several weird problems a while ago and that was because i forgot to update the plug-in... :-(
    Post edited by jerham on
    Hi,Jerham,thanks again for your help,I have the latest vesion of DAZ(4.6) and downloaded the latest version of DCC win 64 bit didnt see any button under 'collide with'-Are u talking about the drop down hierarchy?
    Cool,I think I figured it out:))I deselected the fit-to parameter for Genesis 2 and checked fit to 'none',then scaled up the cloth and positioned it close to proper position on my figure then hit drape,takes a little fiddeling but looks good,at least in still frame:)
    Forgive the bump, related Q with the item. somathat, you are incredibly lucky if you only paid that for this, I'm looking at 24.95 plus the required 49.95 control panel. That is not cheep, and none of the other Genesis 2 items that show in the store search, require the control panel (they supposedly work fine with the free one included with Daz Studio of late).
    I was initially looking for the document page for this (a link would be nice if it is there), tho this thread will do.
    The question I had, was when did that free Studio interface come out, compared to this set? Dose this really need to cost seventy-five dollars, or are the other Dynamic G2M/F items in error with there requirements?
    Would the fifty dollar control panel make the outfits work on Gogo for Mei Lin 6 for example (something other then the default G2F shape)?
    Would I no longer need to drape something from scratch around twenty times before the thing stops on a (whatever it's called) with no poke-threw on the side the camera is on (something I've experienced with a V4 skirt on FW Eve, and others not renderd)?
