RSSY 3Delight to Iray Converter
kksmith6515kksmith6515 Posts: 201
Ok, bare with me here because I'm not the most experienced user and understand very little about shaders and how to change them. I thought that this product would do a lot of the work for me but instead it seems that it's only created new problems. I did read the manual first and deleted the included sky dome and made sure that the headlamp was turned off, however after doing all that and following the three simple steps this is what I got. Please see below. Actually, I think the image FirstBastion posted a few days ago where he simply replaced some of the shaders manually looked much better.
Post edited by Chohole on
  • kksmith6515kksmith6515 Posts: 201
    Opps!! Sorry about that first post! I meant to say in the subject field 3Delight to Iray converter!!
  • IllidanstormIllidanstorm Posts: 655
    edited June 2018
    There seems to be a bug where some stonemason envs. get a red light attached to surfaces. Here for example this one https://www.daz3d.com/tin-pan-alley
    Dosen't matter if photometric mode is turned on or off.
    One can easily fix it but just wanted to let you know.
    1411 x 812 - 317K
    Post edited by Illidanstorm on
  • RedzRedz Posts: 1,459
    Yes there seems to be an error in the red light expression, such that any surface with ‘ed’ in its name is assigned to a red light. It’s possible to change the expression yourself to fix it, but I’m hoping for an update, as there are also errors with the skydome and flame/fire expressions pointing to non-existant shaders.
  • TooncesToonces Posts: 919
    Here's an excerpt from a different post: 'there seems to be an error in the red light expression, such that any surface with ‘ed’ in its name is assigned to a red light. '
    You can fix it in options by getting rid of the | symbol so that goes from: .*([L][E][D][Rr]|[e][Dd]).*
    to: .*([L][E][D][Rr][e][Dd]).*
    That might fix some of the redness issues with your experience. A product update will likely come out to fix a coulpe of the bugs like this, but it's possible to fix them yourself like I mentioned above if you need it sooner.
  • RAMWolffRAMWolff Posts: 10,373
    Ah, you've found the gates of hell I see!  cheeky
  • ChangelingChickChangelingChick Posts: 3,379
    Tin Pan Alley is already 3DL. Are you using the other one to make it Iray?
    Oh sorry. I thought this was the 3DL to Iray thread I'll post it there... or maybe someone can move it to the other thread?
  • Richard HaseltineRichard Haseltine Posts: 109,399
    This discussion was created from comments split from: RSSY Iray to 3Delight Converter.
