Vertigo Hair on G3F
I've loaded Vertigo Hair for G8F on my G3F character.
The fit is perfect.
However, the controls (to move, twist the tails) don't work (as they do on G8F). Why?
The fit is perfect.
AutoFit replaces the rigging with the rigging of the target figure, which destroys any custom bones. It's geenrally easiest, with hair, to position it on the head and just parent it, although for Genesis 3 to Genesis 8 you can just tell it to be a Genesis 8 item by editing it before fitting it.
Thank you Richard. Now the controls work correctly.
Now, which is best: parent the hair to the character or to its head?
Head, otherwise it will be left behind when you pose.
Now, when using the ActivePose Tool to manually pose the hair tail, the whole hair get pulled out from the head...
Did you pin it?
No, I didn't... How do you do that???
It's been a while sicne I used Active Pose, but as I recall it's in the Tool Settings pane.
