Can DIM and DS run at same time?
TSasha Smith
Can DIM and DS run at the same time or is that a bad idea?
Edit old info I tried to open DIM from the start menu but it appears that only the 32 bit version runs. I tried to find the application file in the program folder but not having any luck. What can I do to make sure I get the right DIM to run?
edit: I tried to run DIM it wanted an update, so I updated it. I ran it again and now it was another update? What is going on?
Post edited by TSasha Smith on
Are you following the instructions given in the DIM Update thread. As you have also posted to that thread I am going to close this thread.
