Unable to properly transfer cloth
ForestBoyForestBoy Posts: 76
Hello!
I've created a top for Genesis 8 Female.
When I try to turn it into a real cloth so that it moves along with her, it results in something akward.
I tried using the Transfer Utitily:
I selected "Genesis 8 Female" as the Source, and I selected the "top" as the Target.
In the Options dialogue, I disabled the "Morph Targets" and left everything else as it was by default.
Does anybody know what I could do to make it work fine?
Thank you very much.
Post edited by ForestBoy on
  • Richard HaseltineRichard Haseltine Posts: 108,656
    Was the model created around the base Genesis 8 female or did you use a morphed version? If the latter you have to set Source Shape to match, then enable Reverse Source Shape From Target - though it's better to model around the base figure if at all possible.
  • ForestBoyForestBoy Posts: 76
    Yes, I created the model around the Genesis 8 Female figure in ZBrush, leaving the UVs intact. Then I modelled the top dress around this new model.
    Should I still do this? -> " If the latter you have to set Source Shape to match, then enable Reverse Source Shape From Target"?
    edited June 2018
    Oh man, you did it.
    In the "Source" "Item Shape", I selected "Morph", then I selected my morph in the list, then I enabled "Reverse Source Shape from Target" and left "Morph Targets" checked, and it worked. Thank you so much!
