How does one re-dock Panes?
2»
  • ssllavssllav Posts: 12
    Just close all pane (click and close all tabs). You must see only Viewport. All panes must be close, like on image of laouts. After that try moving undocked panes.
  • VolvoB10MVolvoB10M Posts: 135
    edited December 2020
    I have my entire right side docks missing, when I drag it over to the right nothing happens other than it moving partly off screen, This is unusable with everything in seperate boxes. How do I make up a docking?
    I closed all panes and now I have nothing on screen, boxes reload after selecting them under windows but nothing can be docked so it is worse than it was before.
    Post edited by VolvoB10M on
  • Richard HaseltineRichard Haseltine Posts: 108,934
    Drag by the top bar of the pane group, drop when you see a line of highlight colour along the desired edge. If that isn't working, check that Window>Workspace>Lock Docking/Undocking is not on.
    Lock mode is off but it still will not work. I just end up with them in random boxes still which end up covering the camera controls, I get no highlight or anything and dropping it on the right does not put it in to the one window as it should be.
  • You are dragging the top bar of the pane group (even if ti has only one member), not the tab?
  • To dock or redock floating pane: Click and drag the pane by its Pane Grip. Drop the pane above, below, or to the side of the viewport area. A white line highlights the area when you can release the mouse button. The pane will dock to the closest possible location, based on the locations of other panes in that area.
    Or watch a video by "WP guru" on youtube here:
    https://www.youtube.com/watch?v=z3kvMBiblBQ
