bizarre technical difficulty
so i had technical difficulty, files were missing, i did uninstall delete and reinstall everything, I delete everything in my library and downloaded again everything back into my library why my character eye is all black?
  • khung90skhung90s Posts: 62
    I got another problem not responding, fatal error and daz close by itself, everytime i open ba file. (too many complications)
    1920 x 1080 - 324K
    1920 x 1080 - 125K
  • Richard HaseltineRichard Haseltine Posts: 111,491
    Eyes: that looks as if the opacity maps are not loading. What content did you load, and did you get an error? The error for RuindHDR suggests that soemthing (possibly the Default Resources) is not installed.
    Crash: if you click the More button you should see a more detailed error message, saying which bit caused the crash, and also an opportunity to save a crash report.
    edited June 2018
    i install default resource,RuindHDR  on my documents/daz3d/studio/my library/data i put RuindHDR, i got the same thing, not working
    Post edited by khung90s on
    edited June 2018
    I've been uninstall and reinstalling daz3d for 2 days, i keep getting complications there's something wrong with it. Its not normal. I install it user/Program file/Daz3d as a destination file, Everything else is in /Public document/daz3d/studio,   I got this. I install everything from Daz installer manager It still won't open an environment. And "my library" folder did not show up after i install it. I have too many strange  complications today
    1920 x 1080 - 304K
    1920 x 1080 - 302K
    1920 x 1080 - 320K
    1920 x 1080 - 254K
    1920 x 1080 - 302K
    I can't open most files, not even genesis essentials, which makes it even more useless. somebody help this is too complicated
    1920 x 1080 - 323K
    So you are installing within Daz Studio, or with Install Manager? Please post a screenshot of the Edit>Prefrecnes>Content>Content Directory manager dialogue, showing the actuial assigned paths, and if you are using DIM click the gear icon at top-right to open its preferences, then take a screenshot of the Instalaltion tab and post that.
    Merged threads since they are both about instalaltion issues.
    1920 x 1080 - 363K
    1920 x 1080 - 268K
    I've been uninstall and reinstalling daz3d for 2 days, i keep getting complications there's something wrong with it. Its not normal. I install it user/Program file/Daz3d as a destination file, Everything else is in /Public document/daz3d/studio,   I got this. I install everything from Daz installer manager It still won't open an environment. And "my library" folder did not show up after i install it. I have too many strange  complications today. I can't open most files, not even genesis essentials, which makes it even more useless. somebody help this is too complicated
    1920 x 1080 - 302K
    1920 x 1080 - 302K
    1920 x 1080 - 302K
    1920 x 1080 - 304K
    1920 x 1080 - 254K
    1920 x 1080 - 320K
    1920 x 1080 - 323K
    1920 x 1080 - 363K
    1920 x 1080 - 268K
    heres the log from dim
    1920 x 1080 - 306K
    1920 x 1080 - 388K
    here's the dim log as well
    1920 x 1080 - 306K
    1920 x 1080 - 388K
  • y3kmany3kman Posts: 878
    Have you recently updated Windows? Check if the ransomware protection is blocking DAZ or any of your programs from accessing the Documents directory. This is different from the annoying UAC. Either turn it off or manually add/allow the EXE files.
    880 x 441 - 94K
    867 x 494 - 105K
    You don't have C:/Users/Public/Documents/My Daz 3D Library listed under Daz Studio Formats, which you should since it's the folder DIM is installing to. You do have some of its sub-folders listed, which you shouldn't - nested content directories are likely to cause issues. Similarly you have a lot of sub-folders of C:/Users/Kevin/Docuemnts/Daz 3D/Studio/My Library listed under Poser formats, which you shouldn't - just the My Library folder itself.
    I tried this but it didn't work out
    What happens with those folders set?
    Get out of Smart Content and open Content Library pane, if your content is now in this pane you will to clear the database and re-import the meta data for Smrt Content to work.
