No Menus in 4.6
Hi there,
after a complete new installation of DAZ 4.6 Pro I have the following issue:
When I navigate to "File" I only have the Option to Exit. No Save No Export No Save as....what´s wrong? In 4.5 everything was fine....
Regards Kai
Hi there,
Regards Kai
What Layout are you using, Window > Workspace > Select Layout?
You could try changing to another Layout, and then changing back again to your normal one, and see if that helps.
That´s it! Thanks for the tip man! Now it works as it should :-)
Regards Kai
The Layout data does seem to get corrupted now and then, as you've just found out. If you've customised your setup any from one of the defaults, it might be a good idea to save your Layout to save time if^h when this happens again.
