Cigarettes, Cigars, Pipes - Iray with Glowing Embers & Smoke
katherinepoche_e11a5b0e7e
Could use some cigarettes, pipes, cigars with iray materials and emissive properties for the glow as they are being smoked with plumes for iray.
Might just happen ;-)
it's all around if you care to look for it.
https://www.daz3d.com/sy-rigged-speedy-smoke-iray
https://www.renderosity.com/mod/bcs/smoking-paraphernalia/122120/
https://www.renderosity.com/mod/bcs/cigarette-for-g3f-and-g3m/125741/
As for emissive embers, if the option isn't there, it is very easy to apply it yourself. use the geometry editor to select the part that has the embers and create a new material zone. Then add the DAZ emissive shader to it and apply the original texture to it. Then play with the settings till it looks the way you want.
I am just using a lit cigarette prop, complete with smoke and having applied the Iray material for it found out it applies exactly same materials as the 3Delight version of the materials - a bit miffed, to say the least! Sawpped them to Iray and added a mild emissive on the ash end. As it was a go with new body hair from @ChangleingChick I'll upload the final image on her thread .
