Is there an iray Skydome that does forests or jungles?
All I have so far is a garden with one of those planes (one straight, one curved)
And VERY FAR forests - which really, are plains with a forest super far in the distance.
I hate those backdrop products, where it's a Sears Photography backdrop. I bought a bunch of those when I first started using Daz and they never worked and I am still scarred from that experience.
I'm looking for something that can do a close forest. I have the jungle construction kit AND a...um...um...the garden one that has vegetation as part of the set...
But I'd like a true iray skydome that places us in the middle of a jungle set, close jungle AND NOT a jungle on the horizon. Any ideas?
  • AJ2112AJ2112 Posts: 1,417
    edited June 2018
    Skydomes are primarly visible horizon or sky image.  Not understanding what your trying to achieve.  Construction kits, can create the style of forest you desire, add figures, objects, etc... then lighting.  Or you can add a jungle image of your choice to Environment backdrop, build to backdrop.  If you do not desire to build forest from kit, you can purchase a ready made foreset such as Through the woods by Stonemason, use HDRI lighting.   .
    Post edited by AJ2112 on
  • Griffin AvidGriffin Avid Posts: 3,822
    Well, the thing is, when you make the trees yourself, you have to go DEEP with the dense forestation or else you see some trees and then this huge flat landscape.
    Or mountains...I want to show a far shot, but not an open field.
    I ended using both a cluser of trees AND a fake billboard backdrop.
    The solution would be a circular backdrop that wraps around the scene. Those are availbale as "backdrops" but they are SMALL and apparently designed to sit behind a few people or a small scene.
    I'm asking about something on a much bigger scale that can handle WIDE shots.
  • I know there are forest HDRI in the store. Don't know how they'd handle wide shots.
    DM have a Mezoamerican set with a jungle skydome... Just cut it in half to let a Distant Light through.
    Maybe Terradome can do it. Terradome plus an instancing product for foliage. Maybe there a Terradome product for forests. IDK.
    Good ideas. I think you were right and I'll have to do it manually and just add enough trees or even vegetation/bushes to give the look of a jungle. Maybe even render without the Dome and add a generic forest last layer backing.
  • Carola OCarola O Posts: 3,858
    My first thought would be TreeScapes backdrops by ImagineX as it comes in three sizes, as well as both curved and straight, also comes as mountains and city scapes. Not sure if those are too small for what you have in mind though.
    That's what I used. It was too small so I put real 3D trees in front of it. I also dumped the .jpg into photoshop and gave it more of a nightime color balance.'It worked out okay. Thanks all.
  • HorusRaHorusRa Posts: 1,665
    edited February 2019
    Post edited by HorusRa on
    Bless you, sir. That will be a life saver as I want to do extensive, deep in the woods work.
    Thank you greatly.
  • kaotkblisskaotkbliss Posts: 2,914
    Thank you greatly.
    I've tried a few of those scenes and it's pretty hard to get without instancing a ton of trees. I try to use a backdrop but something just doesn't give me the impression of really dense.
  • Oso3DOso3D Posts: 15,088
    You could make your own skydome.
    Set up an environment with loads of instanced low rez trees off in the distance (ultrascatter is your friend). Use a spherical camera.
    Once done, there you go; it's not a proper HDR or anything, but it's a backdrop suitable for skydomes.
  • MarcCCTxMarcCCTx Posts: 943
    edited June 2018
    https://www.daz3d.com/movie-sets-81-city-blocks
    if you cleared out the center blocks you would have a 360 treelined environment (more forest than jungle).
    You could probable push the 8 sections together to get rid of the roads.
    400 x 239 - 83K
    Post edited by MarcCCTx on
    Great ideas, thank you both :)
  • ANGELREAPER1972ANGELREAPER1972 Posts: 4,559
    came across this site on another thread and there's a lot of great free HDRIs might be what your looking for with several sizes of each just tried one myself a mossy forest with one of my locals created by AM a Tasmanian Devil and because of his size did a close up and the quality of this HDRI very nice the site is https://hdrihaven.com/
    and if you wanna thank the other dazite that had a thread telling about this site https://www.daz3d.com/forums/discussion/253731/free-quality-hdris#latest
    https://www.daz3d.com/gallery/#images/590081
    edited June 2018
    http://www.hdrlabs.com/sibl/archive.html
    Something there might work for you, maybe Topanga Forest B from the first group?
    https://hdrihaven.com/hdris/category/?c=nature&o=popular
    Maybe one of these? Maybe Blue Grotto? Mossy Forest? River Walk 1, Crystal Falls, Monk's Forest....just a couple I noticed quickly scanning thru.
    All the above are free btw.
    Post edited by AllenArt on
    How well does this work in Studio? I've never looked at it closely, because the product page says it's for Poser only.
    Back on topic, you could also add billboard trees for intermediate use, between a row of instanced trees and a backdrop, to reduce the load on resources.
    I'm not at my daz machine but I recall to use the skydome, you have to change it to an emitted and put the color layer in the emiter color. (The term "color" is wrong but I can't remember what the proper term is.)
    The prehistoric hdri is not a dense forested  hdri but it might work.
  • tj_1ca9500btj_1ca9500b Posts: 2,057
    edited June 2018
    Just seconding the HDRI Haven plug.  I've been using these a lot.
    You can do the 'Pines Beach' trick where you have a ground plane in the foreground, which will block out part of the HDRI sphere to help with ground shadows and such, but then you'll need to pick the right foreground feature.  you can also use various HDRIs as the skydome with Skydome products, but this can be a bit of trial and error.  The nice thing about HDRIs is that the 'natural' lighting is simulated rather nicely, at least in Iray (I haven't explored this with 3Delight yet).
    Post edited by tj_1ca9500b on
    edited June 2018
    not actually forests and jungle but this hdri set from MEC4D has a few interesting ones https://www.daz3d.com/mec4d-hdri-gardens-vol-1-megapack on the sale page she also has some 360 video views to view and a video of her product
    MEC4D HDRI Gardens Vol.1 - Megapack in Vendor, Mec4D,  3D Models by Daz 3D
    Post edited by ANGELREAPER1972 on
  • FishtalesFishtales Posts: 6,216
    @Griffin Avid
    If you have Terradome 3 and Forest PrimeEvil 1 I can send you the Scene Subset for this scene.
    It is all the plants from that bundle as a group and I used Ultra Scatter at 5000 for the base and 3000 for the hills. If you have Ultra Scatter you can change the settings to suit.
    1920 x 1080 - 2M
  • jedijuddjedijudd Posts: 606
    edited June 2018
    Fishtales said:
    @Griffin Avid
    Hi is there any way I could get that to?
    Yes sir I have terradome 3! Bless you. You know what, I used it when I first got Daz and I remember it taking forever AND it looked TOO REALISTIC!
    Now, with a more powerful system and a little more experience, I am willing to dive in on that beast again.
    Let's do it!!!!!!
    edited June 2018
    Here is the scene. Right click on the link and use Save Linked Content As and save it to your library.
    http://www.ftscotland.co.uk/temp/Bryce/jungle-terradome3-001.duf
    Post edited by Fishtales on
    Thank you
  • alienareaalienarea Posts: 536
    Not a jungle but a forest hdri is included in this one: https://www.daz3d.com/iradiance-hdri-variety-pack-three
    Semi-transparent jungle backdrops are included Asian River and Missing Jet. I use the Asian River one often as a backdrop to the Jungle Construction Kit.
    That's a great tip off. Thanks.
    I do own the Asian River.
    edited June 2018
    Deep in the Jungle Something Stirs.
    2018-06-11 16:14:17.404 Total Rendering Time: 8 hours 30 minutes 48.68 seconds
    Stopped at 93%
    Click on image for full size.
    1920 x 1080 - 2M
