After creating a new joint that occurs subdivide black line
beginner albumbeginner album Posts: 0
edited July 2013 in Daz Studio Discussion
Hi
I'm using dazstudio 4.6.0.18 64bit
Victoria 6 pro bundle and purchase.
victoria 6 made ​​the extra bone in the toe.
After I saw later subdivide the black line is running.?
In my opinion, create a 'clock toes weightmap
subdivide weightmap're like a reset.
This, I think, right?
Please let me know I need help
Do not speak English too. I used a translator ... I'm sorry.
Thanks for reading.
Post edited by beginner album on
  • Richard HaseltineRichard Haseltine Posts: 109,102
    What do you mean by Subdivide weightmap?
  • beginner albumbeginner album Posts: 0
    edited July 2013
    Hello
    As far as I know pixar subdivide algorithms for DAZ Studio is coming I understand.
    So, thought it would exist subdivide weight.
    You know, the less you pixar subdivide polygons adjustable curvature
    Is a highly efficient way.
    So I
    x, y, z weightmap sds weightmap while resetting the thought was trashed.
    Added under the picture of the four sds method is due to
    2000 x 1202 - 426K
    Have you modified the geometry, or just added a new bone? You should not be getting results like that with the different sub division methods, which have nothing to do with the weight-mapping.
    edited July 2013
    Looks like you might have reversed the winding order with the polygon group tool. I got the same thing when I tried that and with the new catmark sub-d algorithm I get a spike terminating at 0,0,0 center point.
    253 x 185 - 33K
    Post edited by jestmart on
    Hi
    Feedback Thank you very much.
    I want to know what this means winding order.
    Does that mean you had changed polygon normal?
    Okay, so in the polygon group tool How do I reverse the winding order?
    Left big toe All I have to do the same axis (zyx) will only add to the extra bone
    There's so much yet stay out.
    More information is needed
    Studio uses winding order to determine normals direction. With the polygons selected right-click and in the options that pick Polygon Editing / Reverse Winding Order.
    Yeah, you're right.
    The problem was the flip normal.
    Clean surface, and now no black lines
    Thanks a lot million.
    You've been a great help.
