DazStudio4.10 Is Stating That Iray Uber Shader Does Not Exist. ??
Hi There. I've attempted to convert my materials on my prop using the Iray Uber Shader and the "Ignore Images" Tab.
Then the prompt then flags up as Iray Uber Shader does not exist in the folder In DazStudio4.10.
Just how can I then resolve this ongoing issue??? Please Help.
Jason Usher
Post edited by Chohole on
  • Richard HaseltineRichard Haseltine Posts: 109,519
    How did you install the Default Resourcs package?
  • Via The Install Manager. This is not such record of the default rescouce package ever being installed??
    As I then do find this very strange. Can I then reinstall the default rescouce package direct from Daz3D??
    Yes, if you find it in the products tab of Smart Content, or in the Products list in the Content Library pane, then you can right-click and select Install.
  • How did you install the Default Resourcs package?
    Thanks!
    I solved the same problem.
