Help With Pure Hair Catwalk
Star2wotoStar2woto Posts: 0
Well, hello. I'm here 'cause i need help with some hairstyles for example Pure Hair:Catwalk/Messy etc...
When i try to use these hairstyles and render them only this (in the photo) appears not the hair texture.
  • SiscaSisca Posts: 875
    Most of the Pure Hair series default to the non textured version when adding them. Once you add the hair to your figure go to the scene tab and select the hair. You can then go to Smart Content and select Materials and you'll see a list of all the materials that can be applied to that hair. Just double click the one you want.
  • Star2wotoStar2woto Posts: 0
    Thank you very much.
    I used to drag the material to the hair, i didn't tried to double click on it.
  • NovicaNovica Posts: 23,924
    It can be QUITE startling when you first load the hair. It's like, "EEEEK!" When I did several of them last week, they all were that way- but after you do the first one, it's not a surprise.
