DAZ Studio 3.X and 4.X
Is possible install DAZ Studio 3, on a PC where is allready installe DAZ Studio 4?
I need it, because a lot of script has stopped to work in DAZ 4.
Someone has tryed this?
  • LeanaLeana Posts: 12,809
    Yes, you can have DS3 and 4 on the same machine
  • Richard HaseltineRichard Haseltine Posts: 108,465
    Yes, both can be isntalled - though no more than one can be the default action for handling the registered file types. What scripts are failing? Is this a recent thing?
  • Eustace ScrubbEustace Scrubb Posts: 2,728
    For that matter, I've had about eight editions of DS4 (diferent iterations of 4.x, in Public Beta, General RElease, 32- and 64-bit) and DS3.1 installed simultaneously.  But of course, I couldn't really make much use out of most of them all at the same time.  And as Richard pointed out, one can only set one default program for opening any given file type.  I'd suggest adding an "open with ..." action for DS or DSA scripts, so that you can call the other DazStudio versions at need.
  • CriosCrios Posts: 2,998
    Usually i open all files under the software that i use, don't click on icon. For the script that don't working are the importer for the PMD file, i need for some old characters, and the script for export PP2.
    I thought the PP2 exporter had a DS 4 version.
    There's a DS4 version by mjcasual: https://sites.google.com/site/mcasualsdazscripts5/pp2exporterds4
    I've it, but hasn't worked with las DS4 version.
