someday -- mcjDecal
mCasualmCasual Posts: 4,607
edited June 2013 in Freebies
Figure 1 : although the image below was photoshoped
what i'll try to do tonight
( taking a short break from the Aiko3 crop-top )
is to write a script
which lets you stamp an image on a figure, in a WYSIWYG fashion
Figure 2,
create a Primitive plane
create a camera
parent the plane to the camera
zero the plane's transforms
so it's now "in my face"
moved the plane away along the Z axis
it's now in front of the camera
textured the plane with an image
made the surface slightly transparent
aimed the plane/picture at Aiko's shoulder
selected the shoulder's material
i'll leave the complicated but high-performance solutions for later
for tonight's trick, i just need to map the 4 corners of the stamp
so it wont be a distortion-free solution
figure 3, first experimental results with a 1000x1000 pixels map
we can see one of the issues for this low-processing-cost solution
the decals cant be applied across skin texture seams
figure 4
this time, we avoid crossing a texture seam
we use a 2000x2730 pixels map
but we can see the other issue with
we use a 4 UV coordinate map and apply it to a thousands UV coordinates map
so we get very visible distortion
Post edited by mCasual on
  • mCasualmCasual Posts: 4,607
    edited June 2013
    Figure 1 - my first ever script-applied decal
    for now i set this project aside
    and i'll complete the crop-top for Aiko3
    i'll be back in this thread in July or August
    technical details
    the decal was 200x200 pixels
    the source/destination texture was 2048x2730
    the script used the mcjCollider 4 times
    the processing time was ...16 seconds
    as a plugin it would be 1 second i guess
    , most of it for disk access
    Figure 2
    decal was sampled 1000x1000 times ( unfortunately the decal was just 200x100 )
    the source/destination texture was 4096x5460
    the processing time was ...6 minutes
    556 x 720 - 85K
    772 x 999 - 175K
  • DisparateDreamerDisparateDreamer Posts: 2,520
    amazing as always from you! watching with great interest!
  • Eustace ScrubbEustace Scrubb Posts: 2,730
    Make that at least two of us!
  • KeryaKerya Posts: 10,943
    Subscribing ...
  • siocsioc Posts: 326
    Could you finish than script, it would be so awesome :) please, please
