Problem importing G3M Clothes in Poser 2014/11
faisanfaisan Posts: 602
edited May 2018 in Poser Discussion
Hi Guys! I have a problem importing G3M Clothes into Poser Pro 2014/11. I followed the procedure I attach (first export it as an obj file in the Geometry Folder from Poser Runtime and after export it as a cr2 file in the Characters Folder from the Poser Library). When I load and conform it, it seems to be correct, but when I try to move the Figure, the cloth stays in the same place and it gets distorted like I show in the pictures attached.
I have to say I don't have this problem when I export G2 Clothes in Poser. These ones are G3M clothes autofitted to a G2M Figure, thanks to the Autofit Plugin. In Daz Studio it's fitted correctly, the problem is in Poser when it's exported.
Could you help me guys?
Post edited by faisan on
  • faisanfaisan Posts: 602
    I hope you can help me guys. crying
    I wish I could, but I stopped using poser when genesis 1 came out. There might be a few poser users left here, hope one can help you. Did you try asking for help at the poser forums at Renderocity?
  • You should try it with the "Genesis 3 to Poser-FREE Utility" at renderosity.
    You would be better using the Poser forum
    You can move your thread over there by clicking on the gear Icoan in your first post, and selelcting edit from the drop down list. On the next page you will see a box saying Category on the left hand side, the drop down from that allows you to change forums (categories).
    Thank you anyway. Yes, I did and they gave me some options, unfortunately none of them worked :(
    I did, I hope here I can get some help.
    I tried but it didn't work :(
    Any other idea guys?
