Grainy iRay Renders
Can someone give me advice on how to de-grain renders? Thanks in advance.
  • kaotkblisskaotkbliss Posts: 2,914
    Nice scene, looks like it needs to cook longer though.
    What are your Iray render settings?
  • Mr_ EMr_ E Posts: 68
    Where would I find them? I've included a shot of my Filtering tab.
    edited May 2018
    When you click on the render settings tab to start your render, then the Progressive render section
    *edit*
    you will either want to increase the max samples or the render time, or both.
    There are other things you can do to help render times, like adding more light and turning down the ISO to get the same look.
    575 x 488 - 51K
    Post edited by kaotkbliss on
  • plarffplarff Posts: 282
    edited May 2018
    I dont understand why people use the Render Quality option, each to his own but i unable that and play with the Max Samples. Your pc will love it. Start of with 1000Max Samples and up the res rather. Then play with the Max Samples up and down until you are happy with render quality and speed.
    For OP lighting is your best ally wrt grainyness. The more the better.
    As koatkbliss said that is a very nice looking scene.
    Post edited by plarff on
  • AndySAndyS Posts: 1,447
     smiley It's ever again funny to see the complaines about "granity".
    Perhaps with the implementation of iRay an important warning (hint) was missing.
    Hi plarff,
    yes, you ca do so.
    But:
    It depends on the scene setup. Sometimes a limit of 1000 iterations is sufficient, sometimes the convergement has to reach at least 99.9% with Render Quality >= 4. And somtimes both conditions have to be fullfilled. wink
    I prefer to wish: "Ignore all limits. It is only up to me to decide when the render is done."
    But it is ever funny to see how iRay tries to tell me a certain quality status. laugh
    @ Mr. E:
    Nice picture. Looks realistic and as if taken with an old analog camera at very high ASA.
  • nonesuch00nonesuch00 Posts: 18,774
    is a nice picture
    Thanks everyone for the helpful tips and scene complements.  What is this "OP" you mentioned to offset the grain?
    I am not sure how much this will help but besides just clicking the "On" for 'Noise Filter Enable' I always change the 'Noise Degrain Filtering' from 0 to 1. I also use the "Architectural Sampler", located on the 'Optimization' tab, to 'On' for any interior setting.
    I then put my max samples to 15,000 and my Max Time (secs) to 21,600 and check it periodically until I think it looks good.
    If I see that it is not going to eliminate the grain I will then use canvases and overlight my scene to make it easy to render and faster and then take my individual .exr files into PS to do post work and adjust each light group.
    Use these links for canvas info if you are not familiar:
    The second part gets into the editing portion, though he doesn't use PS it is pretty much the same process.
    I know that it is nice to get everything out of the render without doing post work but I have found that some scenes that I want to do really are difficult without letting it run for a long time so I have found myself using canvases more often now. They also have the added benefit of making a scene versatile where you can go back anytime to edit the lighting easily.
    Hope something from this helps you.
    *edit*
    My rendering settings are the same as the one you've pictured, kaotkbliss. T
    Thank you so much.
