Is 'CQ Event Hairstyle' really compatible with Michael 4....
I'm a newbee here and I'm trying to figure out compatibility. I'm trying to figure out if a hairstyle called 'CQ Event Hairstyle' will work with Michael 4. On the product page (http://www.daz3d.com/hair/cq-event-hairstyle) at the top it says 'David Base' is required, but when I go to the 'David Base' page that product is for Michael 3 and is described as being modeled after a smaller version of Michael. I'm not sure if I really need the David Base or not, and if I do will it work with Michael 4. If anybody has used this hair content I'd appreciate any advise about it.
Thanks----B.R.
If you look at the bottom of the product page you will see that it gives the various figures which the hair will fit (compatible figures), including both M3 and M4.
You will find the various fits in the hair once you install it
Thanks Chohole. I was too focused on where it said 'Required Products: David Base'. I do see that Michael 4 is a compatibe 3D figure. I'll give it a shot.
---B.R.---
Great hair. Worked like a charm!
B.R.
Good. I am a great fan of Neftis hairs I must admit, and they do usually fit multiple figures
Yeah, compatibility and requirements can be tricky to figure out sometimes. When in doubt it is best to ask about it. But as a general rule of thumb, if a product says it requires more than one different figure, usually that means it will work with any of them--not that you need to own all of them.
