Does anyone know how to remove the "Subsurface Shade" from an object
I have been doing some playing around with a scene, and I'd like to remove the Subsurface Shader from a few figures. Unfortunately, there doesn't seem to be an item in my library to remove it like I've seen with some other shaders. Any help you can give me would be appreciated.
-Joe
Content Library > Daz Studio > My Library > Shader Presets > DS Defaults. Use the dzDefault to reset it to the Daz Default shader. If you have texture maps applied, ctrl + double click the shader and select Images > Ignore > Ok to retain them.
At the moment, that folder is empty. It is possible that I never had them or deleted them long ago. Does anyone know how I can go about reinstalling them? Thanks.
-Joe
Thanks for that!
I've been trying to figure this out for a week now and for some reason I never considered going back to the default.
Never mind. I just dusted off an old backup harddrive and I found the daz default shader there.
Reapplying the figure's original textures will also remove the Subsurface Shader.
