Have an issue with G8F face
TraceSLTraceSL Posts: 544
For some reason G8 face does not appear to be correct and comes out looking pinched.  Has to be some issue as it appears on every G8 model I have. The side by side is G3 vs G8 character Nylyssa.  See how the cheeks are sunk in and the lips turn up.  Also added an Aiko8.
Is it just me?
Post edited by TraceSL on
  • Cris PalominoCris Palomino Posts: 12,646
    When you load her in, check the Currently Used morphs, in parameters, to see if something else is being dialed in. Also, make sure Show Hidden is enabled. Let's start there and keep going if needed.
  • TraceSLTraceSL Posts: 544
    edited May 2018
    checked used morphs and everything is showing 0.0% - the more I look at it looks like just the lips/mouth that is in issue, some crazy botox.
    1021 x 468 - 167K
    Tryed un-installing G8, V8 and morphs but after reloading same issue.  Any thoughts?
  • https://www.daz3d.com/forums/discussion/210166/g8f-loading-with-a-funky-face  Looks like you are joining the Demona Club devil; or perhaps it's another face morph which is wrongly activated by default and (that's the DAZ bug...) not shown under "Currently used".
    THANK YOU!!! that fixed it!  did not see where the head was listed as 100% but once I deleted the .duf all was good.
