Lost Realms for M4 not fitting to M4 ?
Hello - does anyone know how to get the mermaid tail for M4 in 'Lost Realms' to fit to the character? I expeced it to form fit like other clothing items but I'm not doing something right or something is not working. Screen shot attached. Thanks
I cant seem to get a screen shot to attach to this but it basically puts the tail in the area of the legs but its not 'attaching'
thanks!
https://www.daz3d.com/lost-realms-for-m4-and-h4
    Hide the legs, there really should be a preset to do that.
  • OdaaOdaa Posts: 1,548
    Jestmart is right about why the M4 legs are still showing. If you want to make sure that the tail is fitting itself to M4 correctly, select the tail in the scene, go to parameters tab, looking under "miscellaneous" and look for the "fit to" property. If it shows M4 than it is successfully fitted. If it says "None", click on the word "None" and select M4 from the list that pops up.
  • juantamborjuantambor Posts: 91
    aha! thanks to you both!
