4.6 render crashing problems
Pluck47Pluck47 Posts: 0
Finally fixed the problem i had with getting Genesis 2 to work and now im having trouble getting my render to work. -.-
When i run the render i have it set to Delight and on the best/slowest render setting. It goes through all the light set ups like a normal render does but when it gets to actually saying "rendering" It crashes. Here is a screen grab right as after the popup appeared.
  • Richard HaseltineRichard Haseltine Posts: 109,570
    I suspect, given the complexity of the sceen in the viewport, that you are running out of memory - since it's program Files (x86) you presuambly have the 64 bit version of Windows, so try using the 64 bit version of DS.
