dForce problem
Wallflower
Hello.
Can someone pelase tell me how can i fix this issue ?
Thank you.
Wallflower
Hello.
Thank you.
I think it may be a driver issue - which will require a reboot. It happened to me (Win 7, nVidia driver 397.31) after I updated drivers. After an unknown period of time any 'idle' component (CUDA, OpenCL, OpenGL) just 'went away' only coming back after a reboot. Now on ltest (397.64) and despite a thread suggesting dForce does not work I am not finding an issue - yet!
So that means i can no longer use dForce, right ?
It means you need to figure out what your video card is called and download the newest drivers software for it from the video card manufacturer website :)
That driver should support OpenCL.
@Odaa > Per the screenshot it's a GTX 1080 and the driver is the one previous to the latest driver.
@Wallflower
Go to the Simulation Settings Tab>Advanced and make sure your GTX1080 is selected. Sometimes Studio defaults to the onboard driver. See the attached screenshot.
That's exactly where i am and there is no selectable option, only this error :
Does Iray see your GTX1080? Same type tab but under Render Settings
A pain, but if you reboot and go straight into Daz Studio and check is the card recognised as a valid dForce device?
I just had that happen. The latest Windows update overwrote my nVidia driver with its own. I went to the nVidia website, downloaded the latest driver for my card, installed it, and the problem went away.
I may be wrong but I think there are two problems .... one is the nVidia drivers Win 10 seems to want to install, screwing up OpenCL - see post above by @Exeter about that. The other is one (or two?) recent nVidia drivers with (at least) Win 7 which 'allow' components (such as OpenCL, OpenGL, and CUDA support) to 'go dormant' and requiring a reboot to wake up - the latest (397.64) looks to have fixed this..
Thanks for all your replies and helps. The solution above just solved my problem.
Love you, KISSSSSSSSSS.
@Wallflower "The solution above just solved my problem."
Don't forget this, it won't be the last time Windows 10 does this to you. Replacing Nvidia drivers with a bad Windows Nvidia has been going on since the first release of Windows 10.
I won't, thank you.
