Digital Carvers' plugins
Do you use Digital Carvers' plugins? I'm thinking about getting Anything Goos ton make my figures dirty/hideous and maybe TerrainTools to put cuts in a log as i animate it being chopped.
Any thoughts?
  • UnifiedBrainUnifiedBrain Posts: 3,588
    I don't have any of them them yet, but have heard great comments.  A definite buy down the road.
    You save quite a bit when you get a bundle instead of buying them one at a time.
  • HeadwaxHeadwax Posts: 10,439
    Any thoughts?
    I have anything goos - it's very good for dirtying up edges - i don't use it a lot because I am lazy
    I have ToonPro - I use it a lot for getting line work without the base render - but I have discovered you can get the line work with the built in NPR renderer - but Toon Pro is alot easier .
    Dont have any others sorry
    HW, I'm pretty sure that you have Shoestring Shaders.  Those fresnel effects are fantastic.
  • VIArtsVIArts Posts: 1,526
    Could you throw up a quicke orf Goos on a figure's face?
    i only have toon pro and parchmsnt
    Ah sorry yes!! I bought them from Shoestring itself -from Mark and then Eric took them over.
    Yes Fresnel is good ,plus for animations there is a proximity shader so one object can effect another one's shader - eg induce a n alpha map for a cross section effect
    many of them look super powerful but I havent found the time to play
  • Persona Non GrataPersona Non Grata Posts: 1,365
    edited March 2021
    Post edited by Persona Non Grata on
    edited March 2021
  • JamyJamy Posts: 192
    edited May 2018
    Shader ops is very handy for making ghosts or X-rays
    Post edited by Jamy on
    exemple
    1500 x 1125 - 1M
  • 3DAGE3DAGE Posts: 3,311
    You can currently make a "multilayer" shader in carrara,. and use that to add the effect of dirt (fractal noise) or an image,.. you can have several layers all blending together.
    You could also create a Mixer of your texture map and a noise or texture map to apply a dirty grunge effect, and use a Blender to create areas of dirty/clean.
    for the log chop,.. You can create an object and have it deform via morphs,. or replace it with a damaged version at a keyframe like a swap/replace ,. pickup/putdown effect.
    here's an old example done in C6
    I have some plugins from DCG, they work well,. ..if they didn't,.. they wouldn't sell :)
    Check out Sparrowhawke3D's plugins ... great,. and free
    I don't use plugins much,. i'm just as lazy as Headwax,. well maybe not that lazy :0
    Baker and Fenrics BVH/PZ2 export,. I use those a lot for getting stuff out of carrara.
    Try to experiment with what you have in front of you before you jump at buying all the plugins.
    1000 x 750 - 219K
    Jamy said:
    exemple
    That car is awesome, Jamy.  But are you sure that it was done in Shader Ops?  It looks very much like the Fresnel effect in Shoestring Shaders.
    Whatever, I want it. :)
    Man, this thread is dirty  lol And i zll looks coo
    the proximity shaderr  head wax mentioned earlier piques my interest as well. it would be cool to see how it works
    Thank you for the compliment :-), it's really ShaderOps ... with a Fake Fresnel effect.
    714 x 601 - 159K
    326 x 359 - 44K
    Dang, I better start saving my money. :)
    Thanks!
    heartfresnelheart
    heartblurred reflectionsheart
    heartcarrara causticsheart
