Background quality drop?
SotoSoto Posts: 1,451
edited May 2018 in The Commons
Hi!
I noticed something really weird and don´t know what is causing it.
I have a background image for a render in Photoshop, it looks as intended, just as in my image viewer. I set it as a background in the environment tab and it looks brutally compressed. The size of the bg is 2000 x 2600 (the size of the render).
I am enclosing the difference between the two. Someone knows what could be the cause? I already checked the render settings.
EDIT: After posting, I noticed the image looks even worse in Firefox than it does on my PC. Left side should look fine. I am very confused. :P (the attachment shows the correct size, I only assume it compress things for full image, but that´s not the point lol, I am worried about DAZ Studio)
Post edited by Soto on
  • TaozTaoz Posts: 10,300
    The forum does compress uploaded images, try to download it and you'll see that it's only 61 KB. That the thumbnail shows the original size must be a bug.
    It's odd though, the thumbnail says it's a jpg while the image saves as a png (apparently it is, Irfanview use to complain if the extension is wrong and it doesn't).
  • 3Diva3Diva Posts: 12,024
    I've also noticed that my scenes appear to be a bit darker lately. I don't know if it's a related issue (or even if it's an issue at all - it might even be just me and my monitor or something). Has anyone else noticed a slight darkening of their scenes lately?
  • SotoSoto Posts: 1,451
    It seems to be related to tone mapping. If I disable it, and set Gamma to 1 in the Image Editor option for the background image, the backround renders just as it should. Of course, I need tone mapping fot th scene to look as intended.
    Guess I need to use a better quality background image so the compression doesn´t show during render. Setting Gamma of the background to 2.4 seems to get it closer to the original result. I got too comfortable with the idea of the image background being independent from the render settings :/
  • fastbike1fastbike1 Posts: 4,081
    @Hellboy "I need tone mapping fot th scene to look as intended."
    Since you talk about rendering in Photoshop, why don't you tonemap there?
