Naming UVs
I have imported a model that I created in Blender which contains different UVs. The UVs in Daz are named "Default", "Default 01", "Default 02" etc. Is there a way to rename these?
Do you mean different UV sets? I think you can change the name of a UV set by finding its file in the data directory, opening it up with a text editor, finding its label and renaming it there.
But what you're describing sounds more like the material zones. Not done it for a while but I think you configure all the material zones in the geometry editor.
Thanks @cheetiot I'll look into it.
