Pose symmetry Macro / Plugin / Short Cut
marco95
Hi,
Q1
For adjuste symmetry pose of Yoga, QiGong, hand-Mudra... I must do Shift-Y and then select
Recusive
Right to Left
Miror
many many time
Can I put this parameter as default or create a macro or a new short-cut that do the recursive miror symmetry ?
Q2
An other question I want to save puppeteer with out morph, only pose, is there a way ?
Thank for your idea, tips, links ... for making easly pose with precision
Marc
Q1
when you use Shif+Y symmently (Actually it means "show symmently dialogue" command ^^;)
dialogue window open.
after you adjust your option ( reclusive etc) , select preferenece tab.
click Set prefered option.
or if you check "Set preferd option On Accept."
it auto record the curernt option as Default, when you click Accept.
after that, if you tweak your option, when you Accept, it auto record the option as defult.
Usually, if use comand with Sift key, it execute the command with your preferred option
witout dialogue window .
But symmentlical command include, show dialogue, so that It open dialogue box.
even though you change short cut, or make action icon,
you need to once open dialogue box I think.
but the options your preferred are already recoreded. and it keep the option,
even though you close ds, and re-start ds.
Next time when you use Shift+Y, it auto adapt your option, simply hit "Enter"
Q2
Sorry,,, I can not find way to only record pozing as puppettier dot.
even though I make layer with zero morph genesis, it must record
all morph value as zero.
I really hope new save and record option for puppettier.
to select which value recorded or not like poze preset.
May you report as future request, in mantis bug tracker?
I try to select hip node only, then edit each dot and assgin pozing by poze preset.
but it seems no meaning for me.
If I hope to use the puppetier layer for other character, I need to re-assign each dot
with rock each morph value in parameter tab.
(about pupettier dot,, if you rock morph value, it restrcit the value . but you need re-assgin all dot with current value
to save the new layer for new character)
then,,, if you translfer each dot poze, on ds timeline as key.
ds timeline record, each key with morph value.
but you can save the animation as poze preset to record only
pozing for each key without character morph .
or I may use Edit>Figure>Clear Animation>Clear Figure Shape.
it remove all keys which recordeded morph values. but keep the value for pozing.
Ok :o)
Thank you for your answer for Q1 kitakoredaz
All is right now :o)
For Q2, actualy, when I want to get pose only, from puppeteer ou timeline, I export all the poses one by one (save as Pose Preset) and I reload the scene (with goog morph) and apply each Pose Preset.
Cordialy
Marc
