V6 rendering problem
hello
I am using DAZStudio 4.6
I have installed today genesis 2 product , Victoria 6 included
I just load V6 caracter,pose her ,put new hair on
And test render :rndering problem See picture joigned
i Try some lights from my library :same bad results
On the screen (UI interface)the preview is nice until i click on Render in the menu
If i try genesis 2 base figure rendering is ok not v6
Some idea??
Thanks
Post edited by Martial on
Does a render work with another character?
Is this the default V6, with the normal skin? Are you saying that it renders that way no matter what lights you are using?
Do you have the newish SubSurface Scattering (SSS) shader installed? It was free with DS 4.6 and should be available as a link at the bottom of the download page for that.
I just test again
I think this problem arrives when i just load Victoria6,duf directly Yes i have tried different lights
And others scene with genesis 1 or v4 is rendered correctly
If i first load genesis2 female first and after apply the Victoria6.duf caracter to this gen2 female the rendering is ok
Thanks both of you
I will see if i have the last version of SSS shader
Do you see the same thing if you render the base Genesis 2 Female without V6 applied?
Genesis 2 female is rendering ok
I have downloaded and again installed
16324_SubsurfaceShaderBase_1.1_trx.exe
And i get this result
Not correct again
Image removed. please see this thread for guidelines regarding nudity http://www.daz3d.com/forums/discussion/3279_97/
And Gen 2 V6 using DSON importer and the same material rendered with Poser pro 2014
Just for test not for final scene
