Error Message when DS 4 is loaded
SenaReSenaRe Posts: 39
edited June 2012 in New Users
Hi! I get this message when DS 4 is finished loaded: Duplicate formulas found in files. Make sure that the content is properly installed. See the log file for more details. I have no idea how to read the log file. I'll hold off on putting the log up here until someone says to put it up. But help? It's not really bothering anything (as far as I know) its just really annoying.
Post edited by SenaRe on
  • frank0314frank0314 Posts: 14,778
    Just look for the parts that say Warning and post that portion of the log.
  • adamr001adamr001 Posts: 1,322
    Duplicate Formulas issue was resolved quite awhile back. It generally has to do with the Evolution Head/Body Morphs for Genesis. You need to uninstall the current version, then reset your download and install the latest version.
    There were a few other products that did this as well, I'll see if I can find the list.
  • SzarkSzark Posts: 10,634
    I got this message myself in 4.5 RC 2.
    The log goes from old at the top to the most recent at the bottom.
    You should see something like this Duplicate id "Locket" found in file "/data/Fisty/Jeweled Finery/1-Locket/Locket.dsf" in the log.
    Yeah it doesn't seem to affect anything just as you say a little annoying. :)
  • SenaReSenaRe Posts: 39
    Okay there seems to be multiple warning sections. This is the first one:
    Could not locate getSDKVersion() method in C:\Program Files\DAZ 3D\DAZStudio4\plugins\Reality\FreeImage.dll. Load failed.
    WARNING: interface\dialogs\dzbasicdialog.cpp(164): No parent specified for DzBasicDialog!
    WARNING: QLayout: Attempting to add QLayout "" to QWidget "", which already has a layout
    Could not activate DAZ Decimator evaluation. Plug-in disabled.
    Total class factories: 1072
    WARNING: 3DConnexion Plug-in Error: Could not create Device, CoCreateInstance failed
    3D mouse support library could not be loaded.
    Creating interface
    Successfully created OpenGL viewport for Viewport1.
    Successfully created OpenGL viewport for Viewport2.
    Successfully created OpenGL viewport for Viewport3.
    Successfully created OpenGL viewport for Viewport4.
    Executing startup script...
    Started in: C:/Program Files/DAZ 3D/DAZStudio4
    WARNING: fileinput\dzassetdaz.cpp(2610): Duplicate formula found linking Value & Value in /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Victoria 4/MCMV4EyesClosedR.dsf.
    WARNING: fileinput\dzassetdaz.cpp(2610): Duplicate formula found linking Value & Value in /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Victoria 4/MCMV4EyesClosedL.dsf.
    WARNING: fileinput\dzassetdaz.cpp(2610): Duplicate formula found linking Value & Value in /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Michael 4/MCMM4EyesClosedR.dsf.
    WARNING: fileinput\dzassetdaz.cpp(2610): Duplicate formula found linking Value & Value in /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Michael 4/MCMM4EyesClosedL.dsf.
    WARNING: fileinput\dzassetdaz.cpp(2610): Duplicate formula found linking Value & Value in /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Victoria 4/MCMV4HdEyesClosedR.dsf.
    WARNING: fileinput\dzassetdaz.cpp(2610): Duplicate formula found linking Value & Value in /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Victoria 4/MCMV4HdEyesClosedL.dsf.
    WARNING: fileinput\dzassetdaz.cpp(2610): Duplicate formula found linking Value & Value in /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Victoria 4/FHMVictoria4.dsf.
    WARNING: fileinput\dzassetdaz.cpp(2610): Duplicate formula found linking Value & Value in /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Victoria 4/FBMVictoria4.dsf.
    WARNING: fileinput\dzassetdaz.cpp(2610): Duplicate formula found linking Value & Value in /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Michael 4/MCMM4HdEyesClosedR.dsf.
    WARNING: fileinput\dzassetdaz.cpp(2610): Duplicate formula found linking Value & Value in /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Michael 4/MCMM4HdEyesClosedL.dsf.
    WARNING: fileinput\dzassetdaz.cpp(2610): Duplicate formula found linking Value & Value in /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Michael 4/FHMMichael4.dsf.
    WARNING: fileinput\dzassetdaz.cpp(2610): Duplicate formula found linking Value & Value in /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Michael 4/FBMMichael4.dsf.
    WARNING: fileinput\dzassetdaz.cpp(2747): Could not find property for animation: #FBMVictoria5:?value
    WARNING: fileinput\dzassetdaz.cpp(2747): Could not find property for animation: #PBMGlutesVolume:?value
    WARNING: fileinput\dzassetdaz.cpp(2747): Could not find property for animation: #PBMHipBoneVolume:?value
    WARNING: fileinput\dzassetdaz.cpp(2747): Could not find property for animation: #PBMHipVolume:?value
    WARNING: fileinput\dzassetdaz.cpp(2747): Could not find property for animation: #PBMGluteCreaseL:?value
    WARNING: fileinput\dzassetdaz.cpp(2747): Could not find property for animation: #PBMGluteCreaseR:?value
    WARNING: fileinput\dzassetdaz.cpp(2747): Could not find property for animation: #PBMGlutesLowerDepth:?value
    WARNING: fileinput\dzassetdaz.cpp(2747): Could not find property for animation: #PBMGlutesUpperDepth:?value
    WARNING: fileinput\dzassetdaz.cpp(2747): Could not find property for animation: #PBMGlutesWidth:?value
    WARNING: fileinput\dzassetdaz.cpp(2747): Could not find property for animation: #PBMHipBoneCrest:?value
    WARNING: fileinput\dzassetdaz.cpp(2747): Could not find property for animation: #PBMIliacLine:?value
    WARNING: fileinput\dzassetdaz.cpp(2747): Could not find property for animation: #PBMSacralDimples:?value
    WARNING: fileinput\dzassetdaz.cpp(2747): Could not find property for animation: #PBMKneeBonesVolume:?value
    WARNING: fileinput\dzassetdaz.cpp(2747): Could not find property for animation: #PBMShinsVolume:?value
    WARNING: fileinput\dzassetdaz.cpp(2747): Could not find property for animation: #PBMThighsVolume:?value
    WARNING: fileinput\dzassetdaz.cpp(2747): Could not find property for animation: #PBMCalvesFlex:?value
    WARNING: fileinput\dzassetdaz.cpp(2747): Could not find property for animation: #PBMLegsLength:?value
    WARNING: fileinput\dzassetdaz.cpp(2747): Could not find property for animation: #PBMThighsTone:?value
    WARNING: fileinput\dzassetdaz.cpp(2747): Could not find property for animation: #PBMFingernailsClaw:?value
    WARNING: fileinput\dzassetdaz.cpp(2747): Could not find property for animation: #PBMHandsGecko:?value
    WARNING: fileinput\dzassetdaz.cpp(2747): Could not find property for animation: #PBMHandsMonstrous:?value
    WARNING: fileinput\dzassetdaz.cpp(2747): Could not find property for animation: #PBMThreeFinger:?value
    WARNING: fileinput\dzassetdaz.cpp(2747): Could not find property for animation: #SCLFingersLengthL:?value
    WARNING: fileinput\dzassetdaz.cpp(2747): Could not find property for animation: #SCLFingersLengthR:?value
    WARNING: fileinput\dzassetdaz.cpp(2747): Could not find property for animation: #SCLFingersWidthL:?value
    WARNING: fileinput\dzassetdaz.cpp(2747): Could not find property for animation: #SCLFingersWidthR:?value
    WARNING: fileinput\dzassetdaz.cpp(2747): Could not find property for animation: #PBMHandsThick:?value
    WARNING: fileinput\dzassetdaz.cpp(2747): Could not find property for animation: #SCLPropagatingHandL:?value
    WARNING: fileinput\dzassetdaz.cpp(2747): Could not find property for animation: #PBMNailsLength:?value
    WARNING: fileinput\dzassetdaz.cpp(2747): Could not find property for animation: #SCLPalmScaleL:?value
    WARNING: fileinput\dzassetdaz.cpp(2747): Could not find property for animation: #SCLPalmScaleR:?value
    WARNING: fileinput\dzassetdaz.cpp(2747): Could not find property for animation: #SCLPropagatingHandR:?value
    WARNING: fileinput\dzassetdaz.cpp(2747): Could not find property for animation: #PBMBreastsCleavage:?value
    WARNING: fileinput\dzassetdaz.cpp(2747): Could not find property for animation: #PBMBreastsHeavy:?value
    WARNING: fileinput\dzassetdaz.cpp(2747): Could not find property for animation: #PBMBreastsImplants:?value
    WARNING: fileinput\dzassetdaz.cpp(2747): Could not find property for animation: #PBMBreastsNatural:?value
    WARNING: fileinput\dzassetdaz.cpp(2747): Could not find property for animation: #PBMBreastsSize:?value
    WARNING: fileinput\dzassetdaz.cpp(2747): Could not find property for animation: #PBMBreastsSmall:?value
    WARNING: fileinput\dzassetdaz.cpp(2747): Could not find property for animation: #PBMPregnant:?value
    WARNING: fileinput\dzassetdaz.cpp(2747): Could not find property for animation: #PBMHunchback:?value
    WARNING: fileinput\dzassetdaz.cpp(2747): Could not find property for animation: #SCLChestDepth:?value
    WARNING: fileinput\dzassetdaz.cpp(2747): Could not find property for animation: #SCLPropagatingChest:?value
    WARNING: fileinput\dzassetdaz.cpp(2747): Could not find property for animation: #SCLChestWidth:?value
    WARNING: fileinput\dzassetdaz.cpp(2747): Could not find property for animation: #PBMLatsVolume:?value
    WARNING: fileinput\dzassetdaz.cpp(2747): Could not find property for animation: #PBMRibcageVolume:?value
    WARNING: fileinput\dzassetdaz.cpp(2747): Could not find property for animation: #SCLTorsoLength:?value
    WARNING: fileinput\dzassetdaz.cpp(2747): Could not find property for animation: #PBMWaistWidth:?value
    WARNING: fileinput\dzassetdaz.cpp(2747): Could not find property for animation: #PBMAreolaeDepth:?value
    WARNING: fileinput\dzassetdaz.cpp(2747): Could not find property for animation: #PBMAreolaeDiameter:?value
    WARNING: fileinput\dzassetdaz.cpp(2747): Could not find property for animation: #PBMAreolaePerk:?value
    WARNING: fileinput\dzassetdaz.cpp(2747): Could not find property for animation: #PBMBelly:?value
    WARNING: fileinput\dzassetdaz.cpp(2747): Could not find property for animation: #PBMCollarboneDetail:?value
    WARNING: fileinput\dzassetdaz.cpp(2747): Could not find property for animation: #PBMCostalAngleArched:?value
    WARNING: fileinput\dzassetdaz.cpp(2747): Could not find property for animation: #PBMCostalAnglePointed:?value
    WARNING: fileinput\dzassetdaz.cpp(2747): Could not find property for animation: #PBMLineaAlbaDepth:?value
    WARNING: fileinput\dzassetdaz.cpp(2747): Could not find property for animation: #PBMLoveHandles:?value
    WARNING: fileinput\dzassetdaz.cpp(2747): Could not find property for animation: #PBMNavel:?value
    WARNING: fileinput\dzassetdaz.cpp(2747): Could not find property for animation: #PBMNavelDepth:?value
    WARNING: fileinput\dzassetdaz.cpp(2747): Could not find property for animation: #PBMNavelHollow:?value
    WARNING: fileinput\dzassetdaz.cpp(2747): Could not find property for animation: #PBMNavelHorizontal:?value
    WARNING: fileinput\dzassetdaz.cpp(2747): Could not find property for animation: #PBMNavelOut:?value
    WARNING: fileinput\dzassetdaz.cpp(2747): Could not find property for animation: #PBMNavelSize:?value
    WARNING: fileinput\dzassetdaz.cpp(2747): Could not find property for animation: #PBMNavelVertical:?value
    WARNING: fileinput\dzassetdaz.cpp(2747): Could not find property for animation: #PBMNipples:?value
    WARNING: fileinput\dzassetdaz.cpp(2747): Could not find property for animation: #PBMNipplesDepth:?value
    WARNING: fileinput\dzassetdaz.cpp(2747): Could not find property for animation: #PBMNipplesVolume:?value
    WARNING: fileinput\dzassetdaz.cpp(2747): Could not find property for animation: #PBMRectusOuterDetail:?value
    WARNING: fileinput\dzassetdaz.cpp(2747): Could not find property for animation: #PBMScapulaDepth:?value
    WARNING: fileinput\dzassetdaz.cpp(2747): Could not find property for animation: #PBMScapulaDetail:?value
    WARNING: fileinput\dzassetdaz.cpp(2747): Could not find property for animation: #PBMSternumDepth:?value
    WARNING: fileinput\dzassetdaz.cpp(2747): Could not find property for animation: #PBMStomachDepth:?value
    WARNING: fileinput\dzassetdaz.cpp(2747): Could not find property for animation: #PBMStomachLowerDepth:?value
    Second section:
    Anything after this looks like duplicates. I'm having a "I killed Kenny!" South Park moment after seeing that LOL
    Evolution Expressions (bonus) morphs
    Stephanie 4
    Legacy Shapes M4/V4
    Creature Creator Genesis
    Anubis Genesis
    SWOLE
    Please note you must UNINSTALL these products before simply installing the latest version. If you don't uninstall them then the problem will not go away.
    I did uninstall before reinstalling them. Thanks. I'll just uninstall everything and start over from scratch, or at least give it a try.
    Hmm, if the uninstall didn't work, then you can remove the affected directories by hand.
    They are (per your log file above):
    Then reinstall the latest version of each (should be version v1.2 or higher).
    Okay, thanks
    thx Adam
  • Richard HaseltineRichard Haseltine Posts: 109,440
    edited June 2012
    First, note that Duplicate Formulas is not the same as Duplicate IDs - the IDs are a new issue with DS4.5, not relevant here.
    Second - ignore me, I wasn't reading carefully enough
    LOL I read it as Duplicate ID and not formulas so my bad. I have a ID issue not a formula one
    The Duplicate ID issue also needs content updating, but I do have a script to do the job if you don't want a slew of downloads just now (most of the content from DAZ that throws the error has been fixed already).
    Thx Richard
  • haw2eyezzhaw2eyezz Posts: 7
    I too am having the same problem as SenaRe with duplicate files. However, my problem came about after an upgrade from 4.0 to 4.5 of DAZ. Why bother with upgrade if I have to always uninstall DAZ then reinstall DAZ, then uninstall, just to reinstall. I have a lot of products and can't afford to spend hours tracking down dups caused by a reinstall of DAZ. There has to be a better way then this...............
    They aren't duplicate files - they are errors in certain files that earlier versions of DS didn't catch. If you didn't see the issue until you upgraded to 4.5 then you were using a very old version of 4.0, which may not have given full support to some more recent content, or your error was Duplicate IDs rather than Duplicate Formulas which can be fixed witha script in the short term, though it's worth getting the updated content in the long term (and again, it isn't duplicate files).
  • fruitwortfruitwort Posts: 0
    edited July 2012
    You know, the more I get into DAZ4 and Genesis, the more I can perceive their fantastic potentials ... if only I could get at them!
    I too have been "suffering" from the "Duplicate IDs were found while reading the file ....". I cried with joy when Search actually found this thread, only to end up with real tears of frustration by the time I had read it to the end. I haven't a clue what everyone is talking about.
    I'm sorry, Richard, but you might as well have written your post above in Greek. It makes absolutely no sense to mere mortals such as myself.
    From the following quote by adamr001:
    Stephanie 4
    Legacy Shapes M4/V4
    Anubis Genesis
    SWOLE
    I have to remove and re-install the above. The nearest installed downloads I have to this are:
    Genesis Generation X
    V4 and M4 Shapes for Genesis
    Genesis Evolution Body Morphs
    Genesis Evolution Head Morphs
    David 3 for Genesis
    Which of these should I be re-installing to remove that wretched "Duplicate IDs...." message, which apparently don't affect anything anyway or do they?
    I've search Products to try and find a Stephanie 4 version of Genesis but without success. I have 100s (could it be 1,000s!) of Expressions which will not register on my Genesis characters in whatever form and which I would love to be able to convert to Genesis. Do they exist and if so, where are they? The Genesis Generation X Read Me declares "GenX can translate morph or expression poses from Poser format to DAZ Studio format, so you can still use them to load your characters and expressions from the content library". Yes, but how? And please don't refer me to the Manual Version 1.1. That doesn't help me in the slightest - it is more a declaration of intent than a guide!
    Please, oh please, oh please ... when can we have a Manual?
    Post edited by fruitwort on
    The morphs throw up a different warning - Duplicate Formulas. If you are getting the Duplicate IDs message you either need updated copies of the items that throw the error when loaded (most of those at DAZ, at least, have been updated to avoid the issue) or you need my script to apply the fix to your copy of the items. There's a thread on Gen X where you should find help with that - assuming you are using DS 4.0, it won't yet work in 4.5.
