V6 rendering problem
MartialMartial Posts: 431
edited June 2013 in Daz Studio Discussion
hello
I am using DAZStudio 4.6
I have installed today genesis 2 product , Victoria 6 included
I just load V6 caracter,pose her ,put new hair on
And test render :rndering problem See picture joigned
i Try some lights from my library :same bad results
On the screen (UI interface)the preview is nice until i click on Render in the menu
If i try genesis 2 base figure rendering is ok not v6
Some idea??
Thanks
Post edited by Martial on
    Does a render work with another character?
    Is this the default V6, with the normal skin? Are you saying that it renders that way no matter what lights you are using?
  • Richard HaseltineRichard Haseltine Posts: 108,785
    Do you have the newish SubSurface Scattering (SSS) shader installed? It was free with DS 4.6 and should be available as a link at the bottom of the download page for that.
  • MartialMartial Posts: 431
    I just test again
    I think this problem arrives when i just load Victoria6,duf directly Yes i have tried different lights
    And others scene with genesis 1 or v4 is rendered correctly
    If i first load genesis2 female first and after apply the Victoria6.duf caracter to this gen2 female the rendering is ok
    Thanks both of you
    I will see if i have the last version of SSS shader
  • SiscaSisca Posts: 875
    Do you see the same thing if you render the base Genesis 2 Female without V6 applied?
    Genesis 2 female is rendering ok
    edited June 2013
    I have downloaded and again installed
    16324_SubsurfaceShaderBase_1.1_trx.exe
    And i get this result
    Not correct again
    Image removed. please see this thread for guidelines regarding nudity http://www.daz3d.com/forums/discussion/3279_97/
    688 x 621 - 63K
    edited June 2013
    And Gen 2 V6 using DSON importer and the same material rendered with Poser pro 2014
    Just for test not for final scene
    986 x 918 - 151K
