Issue with Norma
Alpha01Alpha01 Posts: 160
I bought the Victoria 6 pro bundle, everything was installed through the DM, everything else works fine bar Norma, I am getting this message every time I try and load Norma......
Am I missing something ?
    edited June 2013
    Norma requires the Female Body Morphs, see the Product Page here required products : https://www.daz3d.com/norma
    It will still work, but it won't look exactly like the promos without the Body morphs, although the head morph should work without error.
    Post edited by JimmyC_2009 on
  • Alpha01Alpha01 Posts: 160
    Thanks for the information JimmyC,
    I would of thought that these would of been included with the pro bundle, why give you something in a bundle that means you have to buy additional to it.
    I thought that buying a pro bundle, it would provide you with everything you need.
    Hay ho Sigh!
    Yes, I know how you feel.
    Maybe it will turn up as one of the daily freebies?
  • Richard HaseltineRichard Haseltine Posts: 109,254
    You need to bear in mind that it's a V6 pro Bundle, the morphs are the Genesis 2 Female morphs which will also go with Stephanie 6 or Aiko 6 (assuming we get those) - people would be annoyed if each pro bundle had the morphs, feeling they were paying for the same thing multiple times.
