Adding to Cart…
Ok - just double check you want the HDRI not visible?
I can't be off or there wouldn't be anything visible outside the windows. Also all your Shaders are Daz Default and not Iray.
yes, that's correct
I composite the background later on
is there an option to convert them?
I used the Iray Uber Shader that comes with Studio.
I started a render after changing them and, at the moment, it is 2 hours in and only at 3% done, CPU only :)
I changed the main windows to thin glass, but that was about it. Took 11 hours to run to end (using camera 5 PoV).
I'm at six hours and only 4%, POV #1 :)
Hour and a qusrter in on camera 4 and 12% done thus far - but we will see how it ends up.
oops
would you agree better to quit the rendering otherwise this will fry your hardware ?
maybe I try with the other render I think it's called 3dlight or Blender (in Blender it will take roughly 4 hours but cycles has no spectral rendering)
I'm going to have to abandon this render.
2018-05-04 19:41:26.942 Total Rendering Time: 9 hours 27 minutes 1.62 seconds
5% rendered it said but in the log file,
2018-05-04 19:42:54.126 Iray VERBOSE - module:category(IRAY:RENDER): 1.0 IRAY rend progr: 91.84% of image converged
I had to compress it from 10 MB to 2 MB to get it to load :)
Quite happy to let it chug on :)
no, please quit the render this is impossible with consumer hardware
and man, big thanks for trying
but you know, spectral makes a difference damn sweet to see it at least so far
great job
you really sure about that ?
think about your rig or do you have liquid cooling?
