How Do I add a body Texture please?
http://www.sharecg.com/v/90103/browse/21/DAZ-Studio/G8F-FREE-MERCHANT-SKIN-RESOURCE
I've managed to add 3rd part wardrobe items and such, but when I download the above skin, it is just a folder with textures in. Where should I put this please and How do I turn it "on" within Daz3D Studio please?
  • Richard HaseltineRichard Haseltine Posts: 109,527
    edited May 2018
    Textures are applied through the Editor tab of the Surfaces pane - select the surfaces you need to change, whichj is simplest using the Surface Selection tool, then click the little square to the left of the colour picker for the property that takes the map and select Browse..  to load a new image.
  • Textures are applied through the Editor tab of the Surfaces pane - select the surfaces you need to change, whichj is simplest using the Surface Selection tool, then click the little square to the left of the colour picker for the property that takes the map and select Browse..  to load a new image.
    Thank you very much Richard, very different to  how I imagined!
    #s3gt_translate_tooltip_mini { display: none !important; }
  • Thank you so much Richard! Not at all how I thought it would work.
