IRay reflection issue - or bug
2»
  • SimonJMSimonJM Posts: 6,081
    seegsons said:
    SimonJM said:
    seegsons said:
    SimonJM said:
    seegsons said:
    SimonJM said:
    It's just a bit over half (so far as default settings, 2 hour limit, are concerned) done (using shotcam_01) set to 5120x2160, and render settings of Photoreal (finally got that to stick after selecting it over 5 times and having it chnage back!), and Spectral enabled.  The 'outside' (i.e, the hdri) is looking wrong to me, more blown-out than in your example so I may have other settings not the same as you.  Also it is still quite grainy - probably due to the amount of reflective surfaces.
    no kidding...
    sorry I was in town do some shopping with my wife
    https://www.dropbox.com/s/twi5hn4r4s7jqk6/Sierra_Madre_B_Env.hdr?dl=0
    that's the hdri
    I'm endlessly in your debt
    PM me if I can make it up or something
    Wow, that was really small ...!  Ok, will have another go.  If you can screen cap all your render settings and show me I can be sure I replicate what you are wanting.
    sure
    will do in half an hour so
    thanks
    Yes, far more blue to the lighting, will wait for your settings - I'll be to bed soon so will probably kick it off and leave it going, so can ramp up the settings if you wish
    I uploaded the scene file with settings might be easier
    also, each setting has a small padlock icon I thought I mention it because until a few days ago I didn't know it... anyway only those that I thought are important
    updated scene file with render settings
    Ok - just double check you want the HDRI not visible?
  • FishtalesFishtales Posts: 6,223
    I can't be off or there wouldn't be anything visible outside the windows. Also all your Shaders are Daz Default and not Iray.
  • SimonJM said:
    seegsons said:
    SimonJM said:
    seegsons said:
    SimonJM said:
    seegsons said:
    no kidding...
    that's the hdri
    sure
    thanks
    yes, that's correct
    I composite the background later on
    is there an option to convert them?
    I used the Iray Uber Shader that comes with Studio.
    I started a render after changing them and, at the moment, it is 2 hours in and only at 3% done, CPU only :)
    I changed the main windows to thin glass, but that was about it.  Took 11 hours to run to end (using camera 5 PoV).
    I'm at six hours and only 4%, POV #1 :)
    Hour and a qusrter in on camera 4 and 12% done thus far - but we will see how it ends up.
    oops
    would you agree better to quit the rendering otherwise this will fry your hardware ?
    maybe I try with the other render I think it's called 3dlight or Blender (in Blender it will take roughly 4 hours but cycles has no spectral rendering)
    edited May 2018
    I'm going to have to abandon this render.
    2018-05-04 19:41:26.942 Total Rendering Time: 9 hours 27 minutes 1.62 seconds
    5% rendered it said but in the log file,
    2018-05-04 19:42:54.126 Iray VERBOSE - module:category(IRAY:RENDER):   1.0   IRAY   rend progr: 91.84% of image converged
    I had to compress it from 10 MB to 2 MB to get it to load :)
    Click on image for full size.
    5120 x 2160 - 2M
    Post edited by Fishtales on
    seegsons said:
    oops
    Quite happy to let it chug on :)
    no, please quit the render this is impossible with consumer hardware
    and man, big thanks for trying
    but you know, spectral makes a difference damn sweet to see it at least so far
    great job
  • SimonJM said:
    seegsons said:
    oops
    you really sure about that ?
    think about your rig or do you have liquid cooling?
