Vary Transparency -- Is that Possible?
Is it possible to vary the transparency of characters, or parts of characters, or hair, or clothing, before doing an iRay render? I've looked in Surfaces, and I can't figure out how to do that.
  • SimonJMSimonJM Posts: 6,071
    Look for the Cutout Opacity paramter under Geometry under the Surfaces tab.  It can take a greyscale map to have varying opacity.
  • inquireinquire Posts: 2,435
    Are you saying that this will usually or always work? Or, are you saying that this will only work if there is a greyscale map in Surfaces -->Geometry -->Cutout Opacity?
  • hphoenixhphoenix Posts: 1,335
    edited May 2018
    Cutout Opacity (in IRAY, it's a different surface property in 3Delight surfaces) applies to the entire surface.  IF a map is present, it maps transparency across the surface (so you could make only part of the surface transparent).  The value and/or map determine HOW transparent it is.
    Post edited by hphoenix on
    YES! OK, I found it, and I was able to get two items transparent. So it worked for me in these cases. Thank you very much for your help, both of you. I'm grateful.
