Camera wiggle
Hi,
When I move the camera far outside the grid, it starts to wiggle. Is there anything I can do about it?
Info: Moving the other objects, so the car/camera stays at its place, is not possible in my case.
Best wishes,
Thomas
Hi,
Best wishes,
Thomas
Ok, found it out. Modifying "Distance to near plane" does the trick.
That was a new one to me. Thanks for the solution.
Too happy ... but didn't work. In preview, it' ok, but when I render, it doesn't work as expected :(
Hi Thomas :)
I can only reproduce that distortion on the production frame by moving the camera a few Miles away from the working grid,. (in a Medium (30ft) scale scene)
I'd suggest either make a new scene to work at Large scale, or scale down your vehicle.
You can also try changing the SCENE/Interface / Scene's Magnitude ,...to large,.
that should extend the distance at which the production frame distorts,. it'll still distort if you move it too far
Hope it helps :)
Thanks.
