Darker Shadow near object
3dOutlaw3dOutlaw Posts: 2,481
In the picture, I have a "landing gear", but I suppose it can be any object, that is on a plane that is set to catch the shadow. I have UberEnv2 turned on around 35%, and I have a distant light acting as a sun...
The problem I was trying to identify, is that the shadow from the sun is not any darker nearer the object than further? Is there a setting for this?
(The white arrow is the direction of the light/shadow on the ground, and I would expect to see right behind the object it be darker, and get lighter gradually?)
I guess I am looking for a shadow dropoff, but its not included with the distantlight that I can see. Do I have to use a spot and fake it?
  • Richard HaseltineRichard Haseltine Posts: 109,267
    Is uberEnvironment set to one of the Ambient Occlusion modes?
    Its set to "Occlusion w/ Directional shadows"
    OK, perhaps I figured it out. I was not using an image on my UE2 Environment, so there was no "direction" to any shadows. I am trying one now.
    Nope, that did not help. Here are my UE2 settings in case that sheds any light (no pun intended) on the issue.
    286 x 723 - 20K
    What happens if you remove the distant light?
    Thanks Richard, I am not sure what would happen, but I can give it a shot. It seems I would them have to find the appropriate HDR image for UE2, that replaces the lighting that a single sun/distant was giving me :(
    Just as a test, to make sure that UE is working - I wasn't suggesting you render it like that for real.
