Dforce blow ups
I have been having allot of crashing of Daz when using dforce simulation but when it does actually complete a simulation part of the outfit that I'm using blows up. Any ideas on how to get the simulations to work?
I work on an
iMac
Runninf High Sierra
3.4 GHz Intel Core i5
32 GB 1600 MHz DDR3
NVIDIA GeForce GTX 780M 4096 MB
  • Those ThingsThose Things Posts: 1,155
    It helps to use a Dforce compliant outfit. If it isn't Dforce compliant, you can still make it work in many cases, but often you'll need to do some weight mapping work.
  • nonesuch00nonesuch00 Posts: 18,844
    That is the new dForce Mother Goose outfit actually I'm pretty sure.
    It's even hard to get dForce compliant outfits to not blowup when the unintentially intersect an object. Example I tried to dForce the dForce Essentials Dress freebie with the Outdoor Swing freebie but the dress was someone in the simulation intersecting the swing rope & blowing up. You can solve that by:
    1) Make the swing ropes invisible in the simulation by clicking the Eye on the ropes in the scene tab
    2) On the rope surface set the 'visible in simulation' to off
    So you fix your problem in a similar way. Since only the right sleeve is blowing up you know something is intersecting there. Try to remedy that by:
    1) Make the character model static andon the surface tab for the sleeve that is blowing up set it to 'Not intersect with itself' - called 'self collide' I think.
    If that doesn't work hopefully someone that is really good with dForce comes along.
  • Thanks for the suggestions and yes that is the new peasant dress and it is a dforce. I learned early on that I had to turn off visibility on extra items in the simulation, that surely causes problems. I will try the intersection idea, I would really like to use the content I buy and I love the way dforce items look when it does a successful simulation.
  • MartialMartial Posts: 431
    i also have problem with peasant dress Always blow up
    I hope someone find  and  show here the settings  for using this supposed dforce dress
