Edie 8
18910111214»
  • nonesuch00nonesuch00 Posts: 18,774
    Valkeerie said:
    My first Edie, out of the box ...
    nice
  • MollytabbyMollytabby Posts: 1,163
    Really nice image, I love the quality of the features and composition.
  • L'AdairL'Adair Posts: 9,479
    Valkeerie said:
    Second Q involves applying MDL face materials to Edie. Normally I would see these in my texture-shaded viewport, but I don't. I have to switch to the NVidia viewport and then I see them. Is this some G8 shader thing I have missed because I haven't used G8?
    Thanks.
    Edie is still in my cart, so I'm just guessing here: Some of the G8 females are using the Diffuse Overlay for some or all of their makeup options. It's much faster than LIE, but it only shows up when the scene is rendered, or the draw mode is set to Nvidia Iray.
  • ValkeerieValkeerie Posts: 163
    This is also Edie, but I have gone mad with morph sliders.
    1500 x 1500 - 2M
  • 3Diva3Diva Posts: 11,981
    It's a lovely render. Great smile and lighting! My brain is a bit fuddled by the mix of the 1920's style flapper hair, the pioneer era looking dress and bonnet, and the more modern looking necklace. lol
    Really nice
    Gawd, Magento sucks so bad. Anything but Magento for heaven's sake... Joomla,
    Laurie
    Valkeerie said:
    Edie is a fantastic character. I bought the Edie Pro bundle, which is a first for me, buying a pro bundle. I'd stopped buying DAZ products since G8 was released , and Monique 8 is the only G8 character I have (and only because of a huge discount). I've tended to work with V4/M4 and build my own materials out of sheer boredom with the offerings since G2.
    A couple of questions. What is a good subD level to use? I see it goes to 5, but my machine crawls.
    Thanks.
    For subd, usually 3 or 4 is enough. If you're using the HD morph, I'd use 3 or 4. If you're not you can probably get away with two.
    Laurie
    edited April 2018
    Thanks.
    As AllenArt said a SubD of 3 or 4 tends to be all you need for HD. For non-HD I usually don't go above 2. But then again most of the figures I use these days do have HD so I tend to render most of them at level 3. I rarely render above level 3 as it, as you said, can really slow things down going higher.
    To get around using the Higher SubD levels, sometimes just upping the Bump Maps and Normal Maps can give a similar look without being quite as hard of a hit to the computer.
    Most of the new Daz Official "8" female figures use Diffuse Overlay layers for the makeup (and sometimes the brows as well). Diffuse Overlay only shows up when using the Iray preview.
    Post edited by 3Diva on
  • Oso3DOso3D Posts: 15,090
    I wouldn't bother going past 4, and 3 is probably sufficient for portraits.
    If the figure is smaller in frame, like a 'medium' range, 1 or 2 is enough.
    love the steampunk  ensemble make an interesting character
  • I'm still a noob still trying to work at best settings to get the most out of everything so been probably going over board maxing out subd levels and in render settings turning off time limits turning minimum samples to 0 and max samples to max sometimes somehow going way above max settings and rendering quality from 4 - over 6 few times higher and dimension preset to Ultra HD UHD 16:9 3840 x 2160, then other times I just go by defaults cause don't feel like waiting so long and my computer gets HOT as well as the internal fans I have sevaral external fans set up around it to try and keep it cool. I just wanna try and get as much detail as I can though like you see so many others get
  • rayglendenningrayglendenning Posts: 137
    edited April 2018
    Apparently that "losing the PC+ membership" glitch can happen pretty easily when they adjust things for people.
    Is that still going on? I thought it had been fixed more than a year ago — after the switchover to Magento, there was a constant problem of PC+ members losing their status whenever they were given a refund. I could never figure out why Support never automatically checked to see if whatever they'd just done for someone had also borked their membership.
    What time zone are they on as it's still not fixed? :-(
    Post edited by rayglendenning on
  • JVRendererJVRenderer Posts: 664
    edited April 2018
    Grace
    A litte late in the game. Here's a quick render.
    50% Edie 50% Alexandra.  I thought I use a low key 3 point light system to bring out some interesting elements.
    Post edited by JVRenderer on
  • Charlie JudgeCharlie Judge Posts: 13,307
    Mountain Daylight Time: Right now it is only 8:45 am and I think they don't even start work ubtil 9 am
  • Apparently that "losing the PC+ membership" glitch can happen pretty easily when they adjust things for people.
    Thank you, it 16:27 here now and my membership is back
  • Dim ReaperDim Reaper Posts: 687
    Wow!  What a beautiful piece.  Excellent work.  It just goes to show how well Edie blends with other morphs.
    edited April 2018
    I've now received an update to the ticket claiming there was nothing wrong and my PC+ is active... well yes it is working now, but only after supports working day started! I noticed the extra text in red added to the bottom of the PC+ page today!
  • KnittingmommyKnittingmommy Posts: 8,191
    @Valkeerie   I love that portrait! Nice work! :)
    I finally got another chance to render another Edie character. This is the Grandmother for Edie 8. I really like this character.
    You can try rendering out at the "max" settings that you sometimes render with and then lower the settings and render the same scene - then compare the too. Sometimes the quality difference is so minimal that it's not worth adding a TON of render time to a scene. But if the quality is quite noticeable, then the higher settings might be warranted. I'd recommend doing a side by side comparison though.
    I used to render super high and the renders took ages. Lower the settings gave a very minimal quality difference but the render time was much faster. You might try different settings and see the differences (if there is any). :)
  • marblemarble Posts: 7,500
    edited May 2018
    I'm not a G8 buyer but I had to give in for Edie 8 - especially with the coupon today. However, I made a big boo-boo on the purchase. I was checking out the product page and clicked on the HD Add-on to see what it included. I must have forgot to click back and instead clicked purchase. Turns out I have only purchsed the Add-on which is automatically included with Edie 8 for no extra cost. I now have the HD add-on but no Edie 8 :(
    I logged a ticket but I suspect that I will lose my coupon discount which is even more annoying because I bought Dorothea on the same order (same coupon) so I may lose that discount as well. Dammit - so annoyed!
    Post edited by marble on
  • ANGELREAPER1972ANGELREAPER1972 Posts: 4,559
    edited May 2018
    Edie as well as the grandmother hd add on character in the back
    Happy Mothers Day Lingerie 2018
    Post edited by Chohole on
    have done side by sides of same renders like that but in some there does look like I could have gotten away with lower settings and vice versa some could've gotten more out of higher settings bit of a mixed bag sometimes
    Hmmm I've not heard of them taking away a coupon discount. They'll likely just refund you the purchase cost of the HD add-on. :)
    I hope so .. well, actually, I'm hoping they amend the order to Edie 8 instead of just the HD Add-on (which is no use without Edie 8, of course). I'm sure they will be sensible enough to see what I intended to order.
  • WendyLuvsCatzWendyLuvsCatz Posts: 40,295
    a video in iClone 6
    ANGELREAPER1972 I love your lingere render, but my catalogues in the letter box don't look like that! cheeky
  • JOdelJOdel Posts: 6,322
    Just in case someone doesn't check the other markets, AliveSheCried has brought out a set of dialspin characters based on Edie over on Rendo.
    And, yes, they're dial spins. One *could* probably stumble into some of them on one's own. But the thing about dial spin collections is that they go off in all sorts of directions that you didn't realize you wanted to go. And this is a very useful set of a dozen new starting points for building character actors.
