How can I remove Green Arrows from Costume
Hello,
I keep getting these green arrows with some of my costumes (not all) when I place on my model. How can I remove them from the scene? They appear when I export my character as .FBX for animation.
Thanks,
John
  • Richard HaseltineRichard Haseltine Posts: 109,424
    Those are selections handles for bones that control the skirt - if you have AutoFitted the item to a new figure they will no longer be separate bones, so you won't be able to hide them that way. They should have their own surfaces, so you can either hide them through the surface properties (Editor tab of the Suraces pane) or you can select them with the Geometry Editor tool and remove them (click the + next to their surface name in the Tool Settings pane to select, right-click in the Viewport>Geometry Visibility>Hide Selected, right-click>Geometry Editing>Delete Hidden).
