Camera wiggle
Hi,
When I move the camera far outside the grid, it starts to wiggle. Is there anything I can do about it?
Info: Moving the other objects, so the car/camera stays at its place, is not possible in my case.
Best wishes,
Thomas
  • ThomasScThomasSc Posts: 125
    Ok, found it out. Modifying "Distance to near plane" does the trick.
  • DiomedeDiomede Posts: 15,410
    That was a new one to me.  Thanks for the solution.
    Too happy ... but didn't work. In preview, it' ok, but when I render, it doesn't work as expected :(
  • 3DAGE3DAGE Posts: 3,315
    Hi Thomas :)
    I can only reproduce that distortion on the production frame by moving the camera a few Miles away from the working grid,. (in a Medium (30ft) scale scene)
    I'd suggest either make a new scene to work at Large scale, or scale down your vehicle.
    You can also try changing the SCENE/Interface / Scene's Magnitude ,...to large,.
    that should extend the distance at which the production frame distorts,. it'll still distort if you move it too far
    Hope it helps :)
    Thanks.
