SOLVED Vittorio (the male morph for V4) and DzCreateExPFiles-V4 ???????
FauvistFauvist Posts: 2,219
edited June 2013 in The Commons
I've installed all the files for Vittorio in the places specified in the file list. Now I'm supposed to run something called DzCreateExPFiles-V4 . I'm on a Mac. I don't believe Mac's run Ex files. I can't get DzCreateExPFiles-V4 to work. I have previously installed Elite and other large morph packages, so V4 must get updated somehow.
How do I solve this - anyone?
Added: I'm using Poser Pro 2012
Post edited by Fauvist on
  • fixmypcmikefixmypcmike Posts: 19,692
    On a Mac it's DzCreateExPFiles-V4.command
  • surrealitysurreality Posts: 0
    If you still have the 'update V4' shortcut on the desktop, it should ideally work for any of the morph packs -- Vittorio included. It's a generic ExP updater, so if Vittorio is using ExP, it should work. ExP is the 'add morphs to the base' script/code system; it isn't a .exe file. (Lifelong exclusive mac user here. :) )
  • FauvistFauvist Posts: 2,219
    edited June 2013
    Thank you! I did it, and all the Vittorio dials appear in the V4 parameters. But none of the dials work. No matter which Vittorio dial I turn, nothing happens to the V4 figure.
    Added: I clicked on the Vittorio mat pose for skin texture and it was applied to V4, now she looks like Charlie Chaplin.
    It's solved. Closed the program, and shut the computer down. Restarted it, opened the program, and Vittorio was working the way it's supposed to.
    Thanks!
