How to create icons for Genesis files done with exporter
Jenkins3D
I sell pose sets mostly for V4 but I am venturing into the Genesis arena slowly. I made a fighting expression set I will be selling but I need to know how to create the icons that will show for Daz 4 to see them. (The folder in My Library shows nothing when selected) Otherwise I have to put them in the daz3 runtime folder and do it that way.
here is an example of the faces
thanks!
You just need a .duf and .png file wit the same name, outside of the Runtime folder.
how do I make a .duf file? It saves as a fc2 file
In DAZ Studio, the various options under File > "Save as" create .duf files.
one last question, which option and do i need to do settings a certain way just for faces?
thanks!
I assume you just want File > "Save As" > "Pose Preset". You can choose to save the entire figure's pose or just part of it. I assume in this case you only want poses for the head, so after specifying a filename, in the "Pose Preset Save Options" window uncheck everything, then expand the figure under Properties all the way down to the head and check just the head-related checkboxes you want to save.
