Having problems with CMS after fresh install of Windows 10 & DAZ Studio 4.10 [Solved]
RO StudiosRO Studios Posts: 107
[Having problems with CMS after fresh install of Windows 10 & DAZ Studio 4.10 [Help]] Hi everyone, as the title says. I'm having problems with the connection for it, I tried changing ports from this post and I tried that but no luck. Then I uninstalled it on DIM and then reinstalling it manually but no luck from that as well. But on AVG I excluded the folder where the cms in the AppData folder on my computer and again no luck. :(
If you have any help, it will be appreciated.
DAZ Version: 4.10 (Latest)
Antivirus: AVG free
Firewall: GlassWire (But not sure if that's the culprit)
Post edited by RO Studios on
  • Richard HaseltineRichard Haseltine Posts: 108,531
    Have you tried dis thenonnecting from the net and turning AVG and GlassWire off, then launching DS?
  • RO StudiosRO Studios Posts: 107
    Hi Richard, sorry for the late reply and yes did do that and the firewall on GlassWire is already off (and still is). Plus I forgot to mention Malwarebytes is installed but I excluded the folder as well just in case, but that wasn't the problem. And I restarted the computer two times now and did the same thing turning off AVG and going to properties to make it run as administrator. Plus I just change the port back to 1800 and I did everything you asked me to do but no luck on that. And to be honest, I'm getting frustrated with CMS I'm might as well go back to 4.8. I wish the techs would remake Studio on how to handle the content without CMS anymore to show categories and whatnot. But thanks for your help anyway. :(
    edited April 2018
    Okay... apparently installing the beta version of CMS worked and it gave me the port 17237 then it just works like a charm. Just thought I want to note that.
    Setting things to run as administrator is likely to cause problems as it changes the permissions for the files and folders they create.
    Yeah, I turn it off but there's hasn't been any problems so far. So I'm good. :)
  • JMCarriganJMCarrigan Posts: 179
    So where do I find the beta of CMS and switch it out? (I'm 70 so....) I will continue to try and solve theseissues.
    The beta is currently the same as the release as far as the CMS is concerned (and indeed DS, though the beta has been different more recently than the release). I'm not sure why installing a different version would have helped in this case - they use the same database folder, as far as I know, so it wouldn't have been a way rounbd permission issues.
