iRay Water on skin - problem with "cutout opacity"
Okay, so I'm trying to follow this: https://thinkdrawart.com/how-to-get-wet-skin-in-iray
The first bit is okay, the creation of the geometry shell.
But then comes the problem... he tells me to find the "cutout opacity" - but I don't have that - anywhere that I can find?
So... has this been changed, or am I just stupid?
It seems that I'm just being stupid - after doing it, and redoing it a few times over, I finally ended up getting it to work - so I was probably being stupid the first... 20 or so times :D
The tutorial could be better phrased — it doesn't mention that you'll find the "Cutout Opacity" parameter in the Surfaces pane, with the Geometry Shell selected. Scroll down a lot, it's down near the bottom of a long list. Also, if there definitely isn't a Cutout Opacity parameter, the surface might not be set up as Iray at all. The previous default material setting in earlier DAZ|Studio versions (3Delight instead of Iray) uses "Opacity Strength" for the same parameter.
