Four Simple Questions?
Headwax
Hi
asked this at RDNA but no joy yet so I thought I would ask here as well - hope this doesn't put anyone off.
My questions:
I wondered if there is an align tool in poser so I can easily align one object with another in xyz co-ords?.
Can I change the hot point of an object (ie centre of rotation) in Poser?
Sometimes I click on the View Object Button and the object vanishes out of view (must be behind camera etc). I wondered how to get around this?
The quickest way to get to the Pose Camera?
sorry if they are stupid questions!
thanks in advance :)
The rotation center can easily be changed in the Joint Editor, found on the Window menu.
To get to the Posing camera, hit ctrl-comma (,) Ctrl-M will return to the Main Camera...
Thanks WandW, appreciate your quick reply.
So silly question number 5, if the object is not rigged, I am guessing that the joint Editor will not help?
So any way of changing the hot Point in a simple unrigged mesh or primitive?
An easy example of workflow I would like to do would be:
I have a human figure I want to place an object in the hand of - say a stick.
I want to be able to drop the stick into the scene, select the stick and the hand and have their hotpoints aligned with an align tool or similar.
(Then I would make the stick the child of the hand in the hierarchy)
I then would like to change the hot point of the stick so that it is at one end (the end in the hand), and when I rotate the stick afterwards the stick will rotate from that point and not, for example, it's centre.
I was wondering what the best way to do this was?
I have searched for an align tool in poser and have only found other people asking the same question, but no real answers.
You are guessing wrong... ;) just select the prop and you can drag the origin where ever you wish. In fact, at least in PP2014, you can change the origin of a prop using the Origin parameter dials.
I'm afraid I can't help you on the other stuff I just eyeball alignments with the orthogonal cameras, so if there is an easier way, I'd like to know it too... :)
Thanks once again WandW,
I actually printed out the manual but I spend so much time doing 3d at the moment that I haven't had a chance to read it all yet (only 578 pages to go :) )
I did print out the shortcut cards on good card but the fonts are so small you cant actually read them on A4 !
Thanks for the data on the origin parameter. I wouldn't have found that for another week at least !
As far as aligning objects, one plug n person said one of his scripts would almost do it...
I'll go looking for it and if I dig it up I'll let you know (smiley here)
cheers from Oz :)
ah here it is, Ockham, I am a thickhead, it looks like the second script on the page night do it
http://ockhamsbungalow.com/Python/
original thread here
http://forum.runtimedna.com/showthread.php?18632-Align-Tool-for-Poser-like-DS&highlight=align+objects
HEy, that's great! :D I'm always looking to move point and spot lights into fixtures, so this should be a real timesaver! Thanx for digging that up.
pleasure :) thanks for your help too (insert smiley here)
