Classic bob hair rendering completely white
I looked through the forums, and did an internet search and found nothing involving an answer to my problem. I have the classic bob hair which usises Iray. I can't use Iray beacuse my computer doesn't have GPU, so I have to use 3Delight. When I render my image, the hair renders completely white. I have bowl cut hair which also does tis, but if I manually apply the textures, it renders fine. Does anyone have any suggestions?
are you making sure that you are using 3dl shader presets rather than the Iray ones
I don't see any 3dl shader presets.
This may help you
https://www.daz3d.com/forums/discussion/139326/irayto3delight-conversion-script/p1
@Boorsman
Iray will render on the CPU, but will be quite a bit slower than a supported GPU.
