How do I animate a rock rolling down a mountainside?
I've got Carrara 7 Pro. I'm trying to animate a rock rolling down a mountain. Here's what I'm doing:
1. Loading the Mountain Preset
2. Adding a Big Rock
3. Changing the Rock's motion to "Physics"
4. Making sure the Effects Physical Properties allow it to "collide with other objects"
5. Setting the Physical Properties material to Ice
6. Placing the rock above the mountain
7. Setting initial velocity to 200 ft/second on Y and Z Axes (as test parameters)
8. Clicking the Bone-looking Simulate Physics Button
9. I only get a little tiny bit of movement, rather than the rock bouncing down the mountain like I would hope.
What am I doing wrong here? It seems like it should be relatively straight forward.
  • McGuiverMcGuiver Posts: 221
    First,
    If you are using a large scene, it may only move a little since the scale is much larger.
    second,
    you will need a negative value in the "Z" initial velocity, otherwise the rock will rise, then fall with gravity.
    I just tried with -30 ft/sec. and it seemed about right in a medium scale scene.
    Is the default scene gravity turned on as well?
  • HeadwaxHeadwax Posts: 10,456
    edited June 2013
    if you decide to do it by hand there is a plug in http://www.sparrowhawke3d.com/Sparrowhawke3DLaboratory.html
    follow terrain modifier
    not sure what versions of carrara it works in
    also use Bezier's in your tweeners
    though maybe you could use oscillate parameter as well in two of the axii?
    see http://wiki.daz3d.com/doku.php/artzone/pub/software/carrara/06_six/17_animating
    Post edited by Headwax on
  • JoeMamma2000JoeMamma2000 Posts: 2,615
    edited June 2013
    What McGuiver said....
    Keep in mind a few basics:
    1. Stuff falls (accelerates) at 32 feet per second every second. Which means in the first second of your animation it will only travel like 16 feet or so. So if the terrain in your field of view is many hundreds of feet, you ain't gonna see much movement. Falling 16 feet in the first second off a 400 foot cliff isn't going to look like much.
    2. Also, keep in mind the size of your rocks. If your rock is hundreds of feet in diameter it might look way too slow when it falls. Make the rock a realistic size relative to the terrain, and spaced accordingly, and it will fall realistically.
    Real rocks falling down real mountains take a long time to get down to the bottom because of the great distances involved. So you'll either need to zoom way in to a very close, small scale if you want the rock to fall "quickly", or force it by manipulating the scene gravity and/or initial velocity. However, keep in mind this might make the animation appear "off", since stuff doesn't travel like that in real life.
    Post edited by JoeMamma2000 on
    Here's a "cheap 'n cheesy" animation of a rock falling on a terrain. It's an 8 foot diameter boulder, which starts it's fall at about 70 feet above the surface of the stock Carrara terrain. I also gave it some initial velocity and rotation as if it was in mid-fall.
    Unfortunately I probably did something bone-headed so the collision distance isn't right. But for the life of me I can't figure out what I did. Anyway, I think the key is to keep in mind the sizes and distances you're dealing with and compose your camera view accordingly.
    http://youtu.be/RrhId1lxWAI
