Whats this pose and is it available for G3 and/or G8
This main promo image:
https://www.daz3d.com/classic-fantasy-persian-dream-for-v4
Is this a custom pose or part of a pose pack, would this be available for G3 and or G8?
Thanks in advance
  • TaozTaoz Posts: 10,271
    Could be one from Hameleon at Rendo, looks like his style. But must be from an older V4 set.
  • FSMCDesignsFSMCDesigns Posts: 12,845
    edited April 2018
    It's a good exercise in learning to pose things yourself. I looked at the image and did this in a couple of minutes with G8. the shins and feet area will be the trickiest since G8 and V4 bend differently, but the arms are pretty easy and then you can pose the fingers however you want. It's an extreme pose, so make sure limits are on or you will be second guessing yourself the whole way.
    656 x 888 - 914K
    Post edited by FSMCDesigns on
  • MescalinoMescalino Posts: 436
    I guess you are right i will give it a go myself
    edited April 2018
    You do mean limits off, don't you? I gave it a try for fun and I had to turn limits off for almost everything to get close to the look of the one on the promo (G3F):
    700 x 875 - 90K
    Post edited by Taoz on
    No, my image has limits on. I always leave them on unless it's a special case. For users not to experienced with posing, I would always suggest them being left on also since they might encounter issues later on using the pose and not know why.
    As a small help: there are quite a few packs with poses, that look rather generic, but come with options to pose the upper and lower body independently from another and by this to mix poses. So with only a few pose packs and some freebies, of which there are many, you have a good starting point for all the poses you can imagine, with just a little bit of adjustment.
